Question about Proscan 32LA30Q Television
My proscan 32lc30s57 not turn on
The Green light is on but the T.V. is in a black screen, it's like the power supply is not clicking i
Posted by AL Parracho on
Alice Hunte
    New Friend:
Purchase 32 inc Proscan on black friday, 7 months later, tv would not turn on, the light comes on, but screen is all black, what should I do
Posted on Jun 26, 2013
5 Related Answers
Anonymous
SOURCE: WONT TURN BACK ON. WILL A UNIVERSAL REMOTE WORK?
ITS NOT STUCK YOU GOT STUCK BUT ITS NOT, ID LIKE TO HAVE THE MANUFACTURE TO STICK IT ,SORRY LOL... I HAVE HAD THE SAME PROBLEM TWICE THANK GOD I PAID FOR THE EXTENDED SERVICE PLAN WHEN I BOUT IT AT K MART, DUA THAT SOULD OF GAVE ME A CLUE!! LMAO . BUT I CAN TELL YOU WHAT IS WRONG, AT LEAST WHAT THEY SAID IT WAS AND WHAT THEY DONE ABOUT IT BOTH TIMES. THE POWER BOX PWOER CONVERTER THE TV RUNS ON 12VOL DC. SO IT NEEDS THIS TO OPERATE. AND I DON'T KNOW IF A CHEAPER ONE WOULD DO IT OR NOT I TRYED ONE THE SECOND TIME BUT NO HELP UNLESS IT WAS BECAUSE OF THE POLARITY IT PLUG'S IN TO THE WALL AND THEN IN TO YOUR TV,? THIS IS THE PROBLEM CHANGE THAT AND YOU WILL GET YOUR TV BACK. BUT DO YOUR SELF A FAVOR TO SAVE YOU SOME TROUBLE LATTER KEEP THE POWER BOX UNPLUGGED WHEN NOT IN USE IT GETS PRETTY HOT EVEN WHEN ITS OFF, UNPLUG FROM THE LITTLE BOX OR FROM THE WALL. BUT DO IT IT WILL SAVE YOU IN THE LONG RUN. PRO-SCAN IS JUNK GOOD PIX BUT I DON'T EXPECT IT TO BE HERE AS LONG AS MY 1985 RCA LOL... HOPE THIS HELPED. ROBERT . OH YAH LET ME KNOW IF YOU TRYED A DIFFERENT CONVERTER AND IF IT WORKED.
P.S GO TO WERE YOU GOT IT FROM TO FINED OUT HOW TO GET ONE..
Posted on Feb 20, 2009
panchal643Ja
Jayesh Panchal
  • 279 Answers
SOURCE: My 32inch Proscan lcd tv wont power up the green
If you can open than open your LCD tv & checked Inverter Borad it have White & red color connector may be this board is defective.
Posted on Feb 19, 2010
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: When I turn on tv, green light comes on and there
This Proscan 19LA25Q has no relay to make any clicking sound that I can think off. The common problem with this model is the fail backlight inverter board. Did you see the screen flashes on for a second? You should also check the output voltage of the AC adapter, it should be 12vdc with load. Check the surface mounted fuse on the inverter board (this board is really hard to find).
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Nov 06, 2010
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: I have a 47" Proscan
Right now the standby 5vdc power supply for the processor on the main board is working (the standby power supply and the processor are running 24/7, even when the TV is OFF) but nothing else, and since you cannot even turn on the TV at the TV control panel it may mean that the main board is not functioning.
I would inspect the power supply module first though just to make sure it does not have any bad caps, burnt parts since bad DC can make the TV to have strange symptom.
Please read my guides first to understand more.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jul 13, 2011
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
I just got an LG TROMM DIE2512W dryer. I have a power supply cord with three cables (green, black and white) good for 120v.15amp. The green cable is my ground. I connected the black cable from the power...
If you have a red wire then the dryer is a 240v dryer and needs a 240v 30 amp circuit...
Here is the manual for your dryer and it shows the hook up you need on page 17...or part 5 of the manual...
Click here
heatman101
Jul 31, 2011 | LG DLE2512W Electric Dryer
My 1501 Dell Inspiron turns on but I have a blank black screen. The only light that shows is the power light on the upper right side of the laptop.
Power getting to the laptop. Try first to see if this will give a screen image on an external monitor, listen for the sound of the cpu fan, hard drive and DVD rom drives clicking, see if the DVD rom drive will open if pressed.
Then remove battery and AC adaptor, press the power button for 30 secs, refit mains only and try this on mains supply (no battery)
If this fails to boot, check the light on the ac adaptor is a steady green, flashing green indicates power is not fully reaching the laptop (motherboard problems)
If it is steady and the LED power light on the laptop is steady, suspect the DC jack socket. If this feels loose or sloppy, it will need replacing, depending on the type fitted, it may be soldered onto the board, or a wired connector, which sometimes goes bad.
After that, I'd suggest that a capacitor has gone on the actual motherboard and you will need to strip the laptop to check it.
Jul 18, 2011 | Dell Inspiron 1501 Notebook
Screen black. Power light on unit flashes red slowly. Power light on switching adaptor power supply flashed green slowly.
Sounds like the battery might be low which would cause the red flashing light and dark screen. Let it charge for a little bit then try turning it on again. If it still does it with the power supply plugged in, make sure there isn't a lens cover on it, and switch modes or try getting into the menu to see if you can get anything to come up. If that still doesn't work then it sounds like there might be a problem with the camera.
May 03, 2011 | Cameras
Proscan 32LA30Q Television Logo
460 people viewed this question
Top Proscan Televison & Video Experts
matt martin
matt martin
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
