The wobble is similar to having lug nuts loose. it only happens at stated speed of 55 mph or higher below 40 mph it runs normally no wobble at all
Bad tire; shifted layers; check for big bubbles on the sidewalls.
This sort of "wobble" is often the result of wear in rubber mounted suspension components. Control arms, trailing arms, etc.. front and rear will cause this when the rubber in the bushings begin to wear, allowing the component to shift and move more than they are meant to while driving. If not repaired this will cause premature wear in other components.
Wheel or tire abnormalities, lost balancing weight, improper rotation of tires, wheel bearing....there should be some noise associated with the wobble...any noise when turning? Struts worn or broken....torsion bar damage...or motor mount.....my best guess is a CV joint, especially if you hear clicking when turning sharply.
Manually try to turn the CV joints by hand when the car is parked...should not be a whole lot of movement....Any hesitation or rough shifting from reverse to drive ? also a sign of a bad CV joint.
It felt to me like the engine was not firing on a cylinder when I was traveling at speeds 45+....really misleading symptoms to me....but it was my CV joint all along.
Actually any one of the things I've listed could be causing the wobble. But a wobble usually indicated a bent rim, bad tire or the drive line had a bad u-joint.
The CV joints are the drive line. Good luck, work safely and I hope I was more help than hindrance.
SOURCE: 1995 Pontiac Grand Prix: All
Use a air hammer or stop by your local garage and they should have a tool to help you.
SOURCE: I have a 90 Pontiac 6000 that starts just fine
Check your transmission lock-up. It's programmed to come in at at 40mph. You can replace the lock-up to come in at 60mph or better.
Or you may have some ignition wires going bad or distributor cap has crack in it.
SOURCE: Front wheel bearing what is specs for lug nuts
a general rule of thumb in my garage is 100ft/lbs for smaller lugs like cars and 120ft/lbs for larger ones like pickups.
SOURCE: When i drive @ low speeds or speeds of 50mph or
It sounds like you have a tire issue. You might want to have your tires balance at a tire shop.
