SOURCE: LID WON'T LATCH ERROR CODE FL
With that code FL “ Failed to lock” I would start looking at the lid latch mechanism. See this link from another site for lid latch problem.
http://fixitnow.com/wp/2006/09/06/maytag-neptune-fav6800aww-top-load-washer-op-code/
If you want to try to repair or get a better understanding of how to diagnose and repair this machine take a look at the service repair manual.
http://www.servicematters.com/maytag_library/docs/16022808.pdf
I hope this will help with your decision to try a repair or replacement.
Good luck with your issue.
SOURCE: i have a mah5500b. prob is washer will not start
I had a similar problem on my Neptune. All the machine would do is beep. I believed it was a stuck button so I got a new touch pad and that solved the problem. I also substituted a control board prior to buying the touch pad but the problem was the same.
SOURCE: washer wont start with all panel lights on
usually unplugging it will reset the ECU ( main control board ). is the door lock operating correctly? i have seen them do that if he door look isnt functioning correctly. the owners manual might be helpful if you can find it or maybe download it from maytag site.
SOURCE: Maytag neptune stackable washer-not sure of the
try it on a spin cycle if it does not work then it could be your door interlock has failed
