I bought the dimmer new but the instructions were lost. I am doing a new install so my question is, while i have the opportunity, do I need to run 2 separate hot lines to my fan/light?
Hi John,
I'm an electrician and can help you with this question.
The *best* way to plan for this fixture is to install a "3-wire" cable (romex, bx, etc.) designated as "14-3" where "14" is the size of the conductors and "3" is the number of insulated conductors. A "three wire" cable consists of 3 insulated conductors (white, black & red) and an uninsulated or bare conductor. Sometimes, you may find that the cable has 4 insulated conductors and instead of a bare conductor it will be covered with green or green with a yellow stripe insulation. This 4th wire is the ground wire (insulated or not). Either type of cable is acceptable for use.
By installing a 3 wire cable, you will not be required to use a "special switch" or an "RF switch" which are often much more expensive to purchase and more involved to install. You can use two independent switches, consisting of a variable dimmer for the light and a speed controller for the fan, simple "snap" or "toggle" switches or any combination of both if you install into a "2 ganged box". If you opt to install a single gang box, your switches will be needed to be on a single strap (often called duplex switches) and your choces for control will become limited - and likely more expensive, too.
If you run a 3 wire cable, you can install your choice of switches, if you install only a 2 wire cable, you will be forced to use special switches or a standard switch and a pull chain on the fixture (this option is only available to you if there is a constant power source at the fixture). It will cost a little more for the 3 wire cable, but it will provide the most flexibility when selecting fans / switches.
I hope this was helpful & good luck!
SOURCE: Problem Installing 3 way dimmer
hi you have many way to connect it go to http://www.hometoys.com/htinews/dec97/articles/kingery/kingery6.htm
good look
SOURCE: Install a single pole light dimmer
House wires are for a 3 way switch, you will need a different switch
SOURCE: need to replace the HPM dimmer switch with a normal switch
This is not a difficult job. First of all go out to a home depot or other hardware store and purchase one three way switch. They come in white, cream, and brown.
Back home, kill the power to the lights you are working on. Then open up the dimmer switch, the other switch doesnt need to be changed. Now, simply draw a diagram of where each wire color is now connected and remove the old dimmer. Reconnect the wires. Remember that the white wire goes on the dull color screw and the other two go on the brass screws. Turn the power back on.
If you do all this and the switch only works correctly part of the time just reverse the two wires on the bright brass screws. Please mark this answer as a fixya!
SOURCE: control fan/light separately, with only two wires
They are available at Home Depot and Lowes. Hunter makes a wall mounter dimmer that will control the lights and fan speed separately. There is a receiving unit that mounts above the fan to the house wires on one side and the others connect to the fan.
The two hots you mentioned should be a black one and a blue one. The blue is for the lights; the black the fan. Ground everything you can to boxes, etc, if the house is only a two wire system without a ground.
I believe that remote wall switch and receiver runs close to $40.
Sirwriter
SOURCE: End of Run Dimmer Switch Installation
The store doesn't know what they are talking about. And I can't believe they told you to just keep switching wires. Hitting the wrong wires is an easy way to short the dimmer switch out. Take it back and go to Home Depot or Lowes and buy the same type switch you took out.
