Question about Electric Mobility 24 " Seat Merits Heavy Duty Electric Wheelchair
Merits wheelchair 2 center flashing lights when turned on
Turning on and 2 center flashing lights continuous and no movement
Posted by Richard Mckenzie on
Tigre Noir
    Sergeant:
  • 317 Answers
Flash Code 2 indicates that the voltage is too high or too low. Check batteries and cable connections. Charge the batteries. If this fault occurs during battery charging, the charger is defective or not adjusted correctly. Empty batteries will charge. Dead batteries will not normally charge.
Posted on Jun 15, 2013
1 Related Answer
lennieg2000
  • 692 Answers
SOURCE: The first battery light keeps
If you are getting just the red light blinking then the batteries are low and not fully charged. If you have been charging and are still getting just the one blinking light then either your charger is not working or you have bad batteries. Hope this helps
Posted on Nov 12, 2010
Right turn signal doesn't always work beyond three flashes
The turn signals on new fords have two settings: three blinks, and continuous blinks. Small movement will set three blinks. Full movement will turn on continuous blinks. Please check, and if still bad you will need to see a mechanic.
Mar 25, 2015 | Ford Edge Cars & Trucks
Ink light and paper light flash alternatively, printer does not work
Hi - According to the Epson manual that error indicates that paper may be blocking movement of the print head.
Turn off the printer, then open the cover and remove any jammed paper or foreign objects. Turn the printer on. If the lights continue to flash you're most likely going to need a dealer service.
Hope it's the paper.
Good Luck, Mikeywaf
Feb 28, 2011 | Epson Stylus C66 Inkjet Printer
Printer will not print - says check photo tray etc, but ok.
When you see the blue light flashing contineously inside the printer.. it means that it needs technical services... theres no way that you can fix it by yourself... go directly to its legal service center or if it still has the warranty... avail of this..
May 23, 2010 | HP Photosmart C7180 All-In-One InkJet...
I have changed ALL cartridges but 2 red lights flashing. 2nd light just ejects the paper. Cannot see any blockages. Regards Fran
please try the following:
  1. Turn the printer off, and disconnect the interface cable.
  2. Open the printer cover and check for any paper jam or foreign object that blocks that print head movement then remove it.
  3. Close the CD/DVD guide if its open.
  4. Turn the printer back on.
  5. If the error disappears, turn the printer off and reconnect the interface cable. Turn the printer back on and try printing again.
  6. If the error continues, unplug the printer power cord for a few seconds and reconnect it to a different power outlet.
  7. If the printer is plugged into a power strip or surge protector, try plugging it directly into the outlet.
Aug 14, 2009 | Epson Stylus Photo R200 InkJet Printer
Flashing red center light
With most flat panel TVs, the TV turn itself OFF when it has a fail electronic part and the red light starts flashing. They call this "Protection Mode". The flashing red light should be a error trouble code.
But, it's weird that everything is working and the red light is flashing. Since you just recently bought the TV, I would get it check out while it's still under warranty. Better safe, than sorry.
Jul 20, 2009 | LG 26LX1D 26 in. LCD HDTV
How to reset service timer on dash
hold in your trip reset, continue to hold, put in key and turn to position 2, wait about 10 seconds, your triangle light in the center of your instrument panel will flash 3 times, after the 3rd flash, release the trip reset. then cycle your key off and back on. your service light should be off. good luck and god bless!
May 07, 2009 | 2002 Volvo S60
Printer light blinking
Customer Support SUPPORT"; //--> print.jpg Print | email.jpg Email | --> pagelink.jpg Link null.gif KnowledgeBase 433-75x75.gif Product
Product
--> Lexmark Z615 Country / Region:
Country / Region:
--> United States Language:
--> Language:
English Need to download
a driver?
--> Save my information--> Lights Flashing on the Lexmark Z815/ Z816 Color Jetprinter ID: ENUS17112 This document does not apply directly to your Lexmark Z615
  1. First count the number of times the light on the front of your printer flashes.
  2. Then refer to the table below for information about the error condition and recommended recovery procedures.
    Number of Flashes Error Condition Error Recovery 2 Carrier Stall:
    The movement of the print cartridge carrier has been obstructed. Remove any objects blocking the carrier path.
    4 Print Incomplete:
    The print cartridge carrier stopped in the middle of a print job due to obstruction. Remove any objects blocking the carrier path.
    12 Cartridge Short:
    The printer has detected a short circuit in a cartridge.
    1. Turn the printer off.
    2. Open the front cover.
    3. Turn the printer back on.
    4. Remove the color cartridge.
    5. Close the cover. If there are no flashing lights, the color cartridge is short-circuited.
    6. Remove the black cartridge and then reinsert the color cartridge.
    7. If there is no error indicated by flashing lights, the black cartridge is short-circuited.
    8. If you continue to receive an error indicated by flashing lights, both cartridges are short-circuited.
Apr 22, 2009 | Lexmark Z640 InkJet Printer
Hi. Usually this happens whenever tehre is an internal problem that limits the movement of the printhead. Try this(although Epson deosnt recommend doing this)... turn off the printer, then try to pull the printhead manually just a little bit to the left then turn on the printer. This may actually free the movement of the printheads, however, this also depends on the nature of the cause of the malfunction.
Oct 06, 2008 | Epson Stylus Photo R220 InkJet Printer
Turn Signal problem
2003 mini cooper . Went for a clean up,and came back with the righ turn signal on all the time. every thing else works fine when you turn left or 4 way flashers. Any help will be appriciated. Thanks in advance
Jul 30, 2008 | 2002 Mini Cooper
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Electric Mobility 24 " Seat Merits Heavy Duty Electric Wheelchair Logo
357 people viewed this question
Top Electric Mobility Health & Beauty Experts
Rob Hill
Rob Hill
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
