Question about Canon Pixma MG5220 InkJet Printer
Cannon Pixma 5220 won't print business card stock. It prints but the images climb above the card preferations.
Prints same on blank paper . Set on .50 margin at the top the bottom margin will be almost 1 and 1/2 inches
Posted by Anthony Beshires on
bijay
    New Friend:
  • 12 Answers
Change he wire like if there is black wire and blue wire cut it and exchange it
Posted on Feb 26, 2013
  • Anthony Beshires Feb 27, 2013
    That is about the stupidest thing I ever heard! Maybe I shuld cut the top out of it and weld a new one back in there! Pfffttt.
2 Related Answers
themadczar
SOURCE: Can't print business cards. Won't feed from rear tray.
I just spend over an hour on the phone with Canon for the same problem... the resolution is simple. From the Control Panel, select Printers & Faxes. Right-click the mp620 printer, and select Properties. Select Printing Preferences from the bottom of the General tab, then click the Page Setup tab. Choose Print Options at the bottom. Place a check mark in the box next to "Disable the paper source setting of the application software." Click OK 3 times and the problem should be solved.
Posted on Nov 27, 2009
Melvictor Gopez
  • 62 Answers
SOURCE: Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Posted on Feb 13, 2010
Will not print evenly on cardstock business cards
This can be caused by the cardstock slipping to one side as it prints. Make sure when you print you are using the card stock settings found under your printer setup - paper type. Check to make sure that the paper you are usng is meant for your printer, most printers are meant for up to a certain pound of paper eg 120lbs. and going over this could mean that the paper is too heavy for your printer which causes the rollers to slip as it pulls the paper through your printer.
May 30, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Paper goes through tray 1 the image prints landscape on portait
Try placing the business card sheet in the main paper bin instead of the manual feed or adjusting the print orientation from Portrait to Landscape or vice versa.
Sep 25, 2009 | Computers & Internet
Small print and it prints a whole sheet size like a business card
Try going into the printer settings in Control Panel - printers and faxes and right click on your HP printer. A drop down menu will display and at the bottom of this menu there is a section "properties" click on this and property scrren will display. Click on "printing preferences" and a preference screen will display.
click on "page setup" and set paper size to A4 or whatever size you are using.
Gersman
Apr 29, 2009 | HP DeskJet 3820 InkJet Printer
Cannon MP460 will feed paper through printer but not print
Check your printer sharing in the system preferences... make sure it's on.. then when you get the print window, look for your printer under shared printers... try it that way... worked for me on my wifi network here.
Mar 23, 2009 | Canon PIXMA MP460 All-In-One InkJet...
My canon pixma ip1000 prints,but no image/letters/colors ...blank
buy new HP printer you will have no problem with nozzels
Feb 07, 2009 | Office Equipment & Supplies
Cannon printer feed paper
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Canon PIXMA iP1600 Printer
Paper jam with card stock paper
Try Getting a PM kit to replace all the rollers.
Nov 13, 2008 | HP LaserJet 2550Ln Printer
Only prints business cards correctly on plain paper, but not on the card stock.
I am the guy with the hp d'jet D2445. I ran out of card stock in failed attempts. Not wanting to give up I bought more (Avery, no serrations) and it worked fine. Don't ask why.
Oct 21, 2007 | HP PSC 1410v All-in-One Printer
Canon Pixma MG5220 InkJet Printer Logo
339 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
