Marantz SR-5200 Receiver Logo
Question about Marantz SR-5200 Receiver
Pioneer vsx-d307 stuck on mute how can I fix it without remote?
Pioneer VSX-D307 has no sound from right front speaker.
Did you connect a known good speaker to the amplifier's right front output connections? Make sure you also have known good wires for the front right as well. Make sure balance control is set to the middle and not just to the left.
I cant get my remote to work
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remotes", check the 'include description' box. Usually cheaper than the vendors.
2answers
My vsx-305 is stuck on muting and i don't have a remote?
Rotate the volume knob. Contrary to popular belief, manual switches on the front of a unit DO have functions.
I have a pioneer usx-405 reciever for a PDf407. It used to work just fine but recently whenever I power it on in keeps flashing "muting". I looked it up online and a forum said I need a remote...
You mean Vsx 405, right? Model numbers are senseless enough without typos.
Are you saying you DON'T have a remote? How did you ever set it up? There are several CU-VSX105 remotes available on eBay, one at $9.99 and expiring in a few minutes (17:12 PDT). If you get this in time you could snipe it at the last 10 seconds.
http://cgi.ebay.com/Pioneer-CU-VSX105-Remote-Control-Receiver-/170642335146?pt=LH_DefaultDomain_0&hash=item27bb1365aa
Many a Pioneer receiver will come up MUTING if it powered down Muting. It's not clear if you have been experiencing unwanted shut-downs. Unwanted Muting or any other command could well originate with an unintended remote control source. Mask the receiver so it can't see other I/R sources.
I have a Pioneer Elite VSX-05. When I turn it on
check in front of your receiver and check the button wheres say mute press that button and
see if work or buy universal remote.
1helpful
Pioneer VSX-D307 Receiver - no audio using DVD inputs
Sometimes the default on receivers in dvd mode will be digital. Make sure you are on an analog input or just try an optical or digital coax out of the dvd player and be done.
305-vsx
You need the remote...or a universal remote you can program to the VSX-305 to un-mute it.
2answers
Overload
Ok, how much is "a bit"? If you are operating your unit at the 50% or more level, your unit is working as it should, as DVD and CD players output more signal than other sources...accordianman
2helpful
4answers
Pioneer vsx-d307
You have a flashing "mute" on the display?...accordianman
Top Marantz Audio Players & Recorders Experts
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
