Question about Kenmore 96532 / 96534 / 96539 Electric Kitchen Range
Kenmore oven is not heating
My Kenmore range model number 316433610 is not heating properly. Neither the bake or the broil will work. Any suggestions?
3 Suggested Answers
Fred Yearian
  • 5603 Answers
SOURCE: Kenmore model 790-96614407 oven stopped heating
Check that you have not lost one side of the 240 volt line at the receptacle. This would be MOST noticeable on the oven but would also reduce the cooktop.
Beyond that, the thermostat and oven timer are suspect.
Inadvertently setting a delayed start of the oven could cause it of course, but that would be obvious.
Posted on Oct 27, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: oven won't heat on broil or bake.
Typically - Heating elements will not fail at the same time - nor will relays.... so your CLOCK is the culprit in this situation.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 26, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Kenmore oven baking element replaced wont heat or broil
It appears your ERC/CLOCK has failed in this instance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
Sep 18, 2015 | Kenmore Ovens
Need manual for Kenmore oven model#C970-648141
I am looking for a manual to a Kenmore Self-cleaning Convection Oven. I bought it used it has selection for conv bake, conv roast, bake or broil. According to the website, my model number doesn't exist -- really? Everything works perfectly - I just want to understand the difference between "bake" - "Conv bake" and "Conv Roast"
Mar 29, 2013 | Kenmore Kitchen Ranges
I have a Kenmore Gas Range Model 665.72012102. It has never baked correctly despite that I purchased brand new. The past couple of years the amount of time needed to pre-heat is up to approx. 25 minut
That is a long time to heat up. I would check to make sure both your broil and bake ignitors are working. On some, but not all, both come on to preheat, and then the broil shuts off. Another, and more likely culprit would be the temperature sensor located in the oven itself. Its the silverish metal rod protruding from the back wall inside the oven. It could be bad and not converting heat/elsectrical signal properly causing the main control to regulate the temperature incorrectly.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 24, 2012 | Kenmore Kitchen Ranges
KENMORE ELECTRIC RANGE 95032. EVERYTHING WORKS BUT OVEN DOES NOT HEAT.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 25, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
Kenmore Oven
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
PS go to searspartsdirect.com, type in your model number for the exact replacement part number.
Oct 27, 2008 | Stoves 500SIDL Gas Kitchen Range
I have a Kenmore Stove and the bottom (bake) element does not heat up. The top Element is fine. I have replaced the bottom element and checked the fuses and they seem fine. Could it be a control panel that...
You could very well have an Electronic Oven Control (EOC) board problem. There two separate circuits that control the oven BAKE and BROIL functions. If you have replaced the BAKE element, and have ensured it connected properly, the only other component that controls that function, is the EOC. If you post back with your complete model number, I can double check to make sure. The model number will be located on a nameplate somewhere around the oven door opening or lower drawer opening. The reason I need to confirm is because some ranges have a separate relay control board.
May 28, 2008 | Kenmore Kitchen Ranges
Electric Kitchen aid, model kerc607...broil elements
What is the complete model # from the sticker on the range? I will need that so I can look into this for you. I will say that I have seen, in several cases, where the oven control gets a surge and fries after an element has broken.
Nov 10, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Kenmore 96532 / 96534 / 96539 Electric Kitchen Range Logo
327 people viewed this question
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
