Recent purchases of Panasonic ribbons for my KX-P2023 Matrix Printer under brand name PORELON #11516 and or #11600 online or from local retail stores have resulted in ribbon only working for a while and then jamming up inside the cassette. The cassette can be pried apart and it appears that the area where the 2 plastic gears come together to drive the ribbon is where it jams up by feeding the ribbon to ride up over the gears. You can put the ribbon back down where it is supposed to be - but it only cures the problem for a short time. Other than the PORELON product being made in CHINA I have no clue. Any suggestions?
SOURCE: Panasonic KX-P2023 Matrix
hai
apply some oil to the rod . keep the head postion in the last. Try to print with out the ribbon catriage
thank u
SOURCE: p2023 prints garbage with vista
Did you get the Vista driver for your machine from Panasonic? If not, it may not work. I use VM ware and run windows xp in virtual machine in order to use some of the older drivers.
SOURCE: How do you get Panasonic KX-P2023 to print 8.5
for 32 bit
Use EPSON
LQ Series 1(80)
INBOX Driver*
1 INBOX Driver is Printer Driver that is included in Windows 7.
