Question about Frigidaire Refrigerator White Fridge & Freezer Handle Set - 5304485330
Frigidaire PLHS67EGSBO Water/ice maker paddle broken
5 Related Answers
roadbird383
Michael Calligan
  • 40 Answers
SOURCE: Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Posted on Dec 05, 2007
robert samples
  • 1314 Answers
SOURCE: Frigidaire - FSC23F7DS - water dispenser not working but ice maker is
take out the crisper drawers and see if the water tank is frozen is the light on the dispencer lighting up when you depress the paddle and look up in the dispencer to see if the acuating paddis broken we will go from there
Posted on Feb 18, 2008
David Coomer
  • 1073 Answers
SOURCE: Water not flowing into ice maker
yes there is a problem with the water valve or the fill tube that puts water into the ice maker is frozen not letting water into the ice maker
Posted on Apr 17, 2008
Carmen Mikulic
  • 415 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
Anonymous
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
My Frigidaire model FRS24ZGE leaks water from the bottom of the freezer door after using the water/ice dispenser. Any ideas on a fix?
Posted on Jul 18, 2009
Frigidaire professional refrigerator
Sounds like you have a problem with water valve/triple solenoid assembly. It controls the flow of water to the door and ice maker. I believe it comes as a complete unit.
Dec 28, 2013 | Refrigerators
Ice Dispensing Paddle is Broken
Not sure about the frigidaire,but most front panels can be removed from front. If you look around outer edge of trim piece there might be little screwdriver slot. Carefully pry off trim piece(faceplate),disconnect electrical plug on back,set aside.Once removed you should see you solution for removing paddle.
Jul 23, 2013 | Frigidaire Refrigerators
Frigidaire plhs3teesbe model won't make ice
Hello - If your ice maker has stopped producing ice completely, you can try to check the following:
1. It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
4. Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Oct 03, 2012 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire french door refrigerator not making ice
Hello jcwilson2929 - If your ice maker has stopped producing ice completely, you can check the following:
3. When was the last time the filter was changed? Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency. The ice maker fill tube may be blocked with ice or have a clogged water filter. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
Sep 26, 2012 | Frigidaire FGHB2844L (27.8 cu. ft.) French...
Installed new valve, getting water to valve but ice maker will not cycle or call for water
GE's ice makers are harvestable, means you can manually tell the ice maker to harvest or cycle. Turn ice maker off, went 5 seconds, turn ice maker back on, tap the paddle 3 times (push the paddle inward completely) then it should cycle, may have a delay like 20 second. I hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 12, 2011 | GE WR57X10033 GE Refrigerator Water Valve
Water supply tube keeps freezing off water supply.
its hard to tell but most likely the valve is not closing all the way. but it could be the ice maker calling for too much.... www.whirlpoolpartssurplus.com
Jun 23, 2009 | Frigidaire FRS3R5EMB Side by Side...
The arm on the ice cube maker is broken.
how to replace water dispensing paddle on a side by side
Apr 06, 2009 | Refrigerators
Need new paddle
Donvier's icecream maker brand was apparently sold to Rival. Not sure whether Rival supports their old models,though.
Aug 05, 2008 | Donvier Ice Cream Maker 1 Quart
Water Dispenser for Frigidaire
try mashing the wire end connector gently with a pair of pliers to tightn the connectorer and let me know if it stayes on
Jan 15, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire Refrigerator White Fridge & Freezer Handle Set - 5304485330 Logo
59 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
