After a shutdown during update, my pc wouldnt connect to any network and gain internet. I tried system restore point, several times but didnt work.
Sounds like the network card has either malfunctioned and would need replaced, or the driver has gone corrupt. Try going to
"right click my computer, click properties, in the left pane choose device manager, then network adapters. Find your network adapter and right click and click "uninstall" Then reboot your computer. Your computer will find your network adapter driver upon reboot and it will reinstall it. Also try resetting your modem. If this all fails, I would say replace your network card. Hope this helps.
yeah ive tried uninstalling it some times, by downloading drivers from the HP site
downloading and installing new drivers over old drivers is sometimes what makes the drivers go corrupt in the first place, uninstall the drivers competely using the method I described, and let the computer find its own drivers and reintall on bootup.
You only need to check the BIOS if you cant install the driver Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"
its 9 driver listed under network card in device manager
check your antivirus and firewall settings also click start type cmd press enter then type ipconfig press enter again you will see all of your internet settings
Step 1:
wireless or hard wired ethernet connected ?
The HP Mini has built-in Bluetooth capabilities that allow you to connect keyboards, mice and other Bluetooth-enabled accessories without using wires. Before you use the Bluetooth on an HP, you first need to enable it. Powering the Bluetooth on the computer on is easy to do, however, and should only take a few
Click on the start menu from your computer's desktop. Select "All Programs" from the options on the Start menu. Choose "My Bluetooth Places" from the program menu. Choose "Power On" from the menu when it appears. Select "Search for new devices" from the menu to locate and connect your Bluetooth accessories to your Mini.
