Win 7 not install in my pc due to sata hdd not show & massege given display (no drives were found.clik load driver to provide mass storage driver for installation & top headline massege given (where do you want to install window ) so i request pl. solve my problem its a very urgent.
Hello here are the homepages:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=531&CategoryID=1&MenuID=16&LanID=9
Here are the other model ( version 3,1 )
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=548&CategoryID=1&MenuID=16&LanID=9
This is important when the drivers needed to be found.
But here seems to be no drivers for windows 7.
Here is only drivers for vista and xp, and there is absolutely no guaranty, the drivers will work on windows 7.
You need to setup the bios boot settings, in order to boot from the drive.
First boot device dvd drive, and second the harddrive.
This selection is urgent, when installing windows.
Other selections maybe needed, depending on the bios version.
The sata drive, should be shown in the bios main meny, when entering the bios.
I suggest you to download the manual, if you don`t have it, and read the setup install section, for basic boot procedure.
Good luck
SOURCE: XP freezes display just before welcome screen
Kaiwah, You never said how old the MB is, but it looks like the onboard video is bad. If it is still under warranty have them fix it. If not go out and get a new board. I have seen yours for about less than $100.00 bucks
SOURCE: SATA drive
Do you have the raid drivers installed ?
check with your mb instructions on correct install procedures.
check mb offical site for update of mb drivers .
is another op system on the drive you are trying to reformat?
is the drive setting on slave , master .or cable select?
check these see if it any help ..
SOURCE: can not install windows xp
hubag, you need to check your bios. At boot up, press the delete key every 2 seconds & your bios will load. Make sure your SATA drive, (s) are listed example: {if your SATA drive is a Seagate the bios will show it as: ST3250823AS}. You should unplug any IDE hard drives connected to the system while installing Win XP. The Southbridge integrates a Serial ATA host controller that is SATA v1.0 compliant, supporting Ultra DMA 150 (SiS964 only). If you do not have your manual you can download it here at:
http://www.ecsusa.com/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=392&DetailName=Manual&DetailDesc=&CategoryID=1&MenuID=6&LanID=9
661FX-M(V1.0B)
Once the bios is set & see's your SATA drive so will windows.
If you can not set your bios to list your SATA drive windows will never install on your SATA drive. You can also use the above link & down load drivers, including a RAID driver.
SOURCE: SATA HDD
you have to update your Bios./in your manual ,you can find on how to update your Bios.
SOURCE: add sata HDD
Make sure the power cable of SATA hard drive is properly plugged in or not.. It is possible.. Try with SATA 0..
Thank you........
