I want to scroll with two finger on touchpad. so how can i do this?
Step 1:
The scrolling feature on a laptop touchpad can take some getting used to, which causes some users to disable the feature. Whether scrolling was intentionally turned off or never enabled on the laptop, it can easily be turned on from the "Mouse Properties" menu.
Click "Start" (or the Windows logo button in Vista and Windows 7) and select "Control Panel." Select "Classic View" in Vista if not already displayed. Double click "Mouse." You may also access "Mouse Properties" in Vista and Windows 7 by clicking the Windows logo and typing "Mouse" in the search box. Press "Enter," then click "Mouse" when the search is finished. Select the "Hardware" tab. Select the touchpad and click "Properties." Click "Change Settings" if the settings aren't displayed. Click the "Device Settings" tab in Windows 7 and select the touchpad. Click "Settings." Click "Virtual Scrolling" in the touchpad properties window. Click the boxes next to each "Enable Scrolling" box and click "OK." Scrolling is now turned on for your touchpad.
SOURCE: How do i get drivers for my touchpad and keyboard
to be frank about this query, windows 7 does not have proper drivers for most of the device, which win XP and vista supports.
it is new operating system and it is still not fully supported by most of the previous versons of windows.
only solution is to down grade your system (laptop) to vista so that it will be compatible.
thank you
colticz
SOURCE: Touchpad and buttons won't click on Sony Vaio
it could be caused because of hardware failure or software failure, in case of hard ware failure it would be best to call sony tech support but in case of software issue , if you remember the day it was working fine,
do a system restore to the date it was working fine, which will reset your software configuration to the date you know it was working ok, so if it was caused by software issue it will be resolved, but any programs that you installed after the restore date will be lost
to do system restore
reboot your system when you see the sony logo start tapping the F8 key and you will come to a menu here select safe mode and boot and then
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts select the bold date your system was working fine and continue as it guides,
If you think the information i gave you was helpfull please do rate me
Regards
Ltoso
SOURCE: asking for all driver for vaio vpccw21fx
for software and driver download of your computer. Please click this link.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: I had Windows Vista in my Sony Vaio VGN-FW21L but
You have most likely got no or the incorrect driver for your touch pad.
I would browse http://esupport.sony.com/ and download all drivers that you need.
Hope that helps.
