Question about Connex 3300 240-Channels Base CB Radio
Connex 3300hp not receiving at all rx tx light on front not on, key mic turns red
Can anyone help
Posted by steve beetz on
Robert
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 54 Answers
MAKE SURE ALL THE CONTROLES ARE SET CORRECTLY R-R GAIN CLOCKWISE FULLY, SQUALCE COUNTER CLOCKWISE FULLY AND HAS THE RADIO BEEN MODIFIED FOR THE 11 METER BAND BY SOMEONE
Posted on Feb 27, 2013
4 Related Answers
jcameo7270
Jeffrey Cameo
  • 675 Answers
SOURCE: Connex 3300HP old model. Dead keys no modulation
Try the voltage regulator or the power supply circuit
Posted on Jan 23, 2011
One Wire
Dean Pitts
  • 126 Answers
SOURCE: Manual for Connex 3300 HP
The best place for anything related to cb radios and ham radios is www.cbtricks.com.
Here is a direct link to the owner's manual for a Connex 3300hp
http://www.cbtricks.com/radios/connex/cx_3300_cx_3300hp/graphics/connex_cx3300_cx3300hp_om.pdf
Dean Pitts
Rollin CBs
Posted on Aug 31, 2008
Anonymous
SOURCE: CONNEX
voltage regulator
Posted on Sep 15, 2008
Melanie Rogers
  • 219 Answers
SOURCE: rx/tx light flashes red and green at same time
sounds like a bad pll.that will have to go to a shop that knows what they're doing.good luck
Posted on Apr 13, 2010
My connex 3300hp radio randomly transmits and gets stuck without pressing mic button. It in sticks if you press mic button.
Have you tried keying it without the coax attached ? Take the mic apart and give it a squirt of electrical parts cleaner .Try using a different mic also.
Feb 17, 2018 | Connex Radio Communications
How do I wire a MIC on a Cobra 29 LTD classic 4 pin mic?
would need to know the mic wire code you going to use. but half moon cut out at top as you look at it is top left 1-4 next row left side 2-3. 1 is cable/ unshield (common). 2 is MOD 3 is TX 4is RX... 1 is wire with no cover 2 is with cover rapped round wire RX is received TX is transmit, hope this helps. newer mic have different code wires so check with meter, red green and blue and shield is on some of the new wiring.
Oct 10, 2014 | Cobra 29 LTD CB Radio
Does the connex 3300hp have talk back
Any radio can have Talk Back.. all it is is leaving the RX active on TX and the sampled audio goes to the speaker that you can hear....
Feb 17, 2014 | Connex 3300 240-Channels Base CB Radio
My tx rx light comes on when i key mic on my connex 4300hp ,,why
Check the mic wires inside the connecter, there might be a loose or broken wire that is making an intermittent connection.
Dec 28, 2013 | Cobra 29 LTD CB Radio
Got a connex 3300HP has a ranger board and chipset won't modulate recieves fine keys up relay clicks needle doesn't move no voice either cant find schematics
You may have a dead meter.
Modulation is audio's affect on swing wattage or pep. Notice that needle moving more with your voice.
Dead key or carrier wattage is without your voice enhancing the power only with mic keyed.
I can only assume that the chipset you are referring to is an ic chip audio or pll which must be working if you are receiving audio.
Check your mic cord................ transmit and modulation and even your receive volume can be affected by the cord/mic plug solder joints or broken wires here.
http://www.cbtricks.com/radios/galaxy/dx33hp2/graphics/dx_33hp2_sch.pdf this is a similar radio the General Lee, Connex 3300hp and Galaxy hp2 share boards i believe dont hold me to that thou.
Aug 20, 2011 | Connex 3300 240-Channels Base CB Radio
Have a new connex 3300hp i can hear everybody else but nobody can hear me when i key up and talk the needle dont even move
look up the tune specs VR13 (L PWR) L32 L33 high power maybe your watts are turned down if it is brand new send it back to the place you bought it from.If the watts are turned all the way down you won't get any carrier your needle is not moving when tranmitting there is no rf power check to see if your tx light is on when depressing the mic button. you should have a rf adjustment turn it clockwise to turn the power up on the front of your radio.or the mods i gave you in the radio.
Mar 31, 2011 | Connex 3300 240-Channels Base CB Radio
Put another **** on 29 ltd and lost key up and receive but it still lights up. What you thank is wrong. 5 different mics, all work in my other radios. I heard something chatter and it would not tx or rx...
Check to make sure that there is noting shorting out inside of the radio. some mic plugs can turn from overtighting the mic connector.. also check the pins they may be broke or compressed too much and won't make connection to any mic.. Pin 1 is ground and pin 4 is rx.. take a jumper wire across those and see if you get rx back. same for tx pin 3.. jumper pin 1 and 3 should have a key up. pin 2 is your of course audio. these should be first things to check. cobras unidens and galaxys, connex, genlee etc. are wired the same. midlands and radioshacks ge are different. so make sure your mic is wired for a cobra or galaxy also.. any mic will work on any radio. as long as is it wired to it correctly....
Dec 15, 2010 | Radio Communications
Rx/tx light flashes red and green at same time
Apr 01, 2009 | Connex 3300 240-Channels Base CB Radio
No squelch
Yep that should happen.
Green or no color in receive mode
Red when you key the mic to let you know when you are transmiting
Feb 28, 2009 | Cobra 29 LTD CB Radio
Connex 3300 mic wiring
I opened up one of my Cobra HighGear mics and here is how it is wired:
1. shield (Bare copper wires) --- twist them good and tin with a little solder
2. audio (White)
3. transmit (tx) (Red)
4. receive (rx) (Black)
Blue and Yellow are unused.
Dean
Rollin CBs
Jan 27, 2008 | Connex 3300 240-Channels Base CB Radio
Connex 3300 240-Channels Base CB Radio Logo
570 people viewed this question
Top Connex Radio Communications Experts
Tony Raia
Marvin
Marvin
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
