Computers & Internet Logo
Anonymous Posted on Feb 25, 2013
Why does my video stall on anything - Acer Computers & Internet
joecoolvette
Level 3:
  • Acer Master 5,660 Answers
  • Posted on Feb 25, 2013
joecoolvette
Acer Master
Level 3:
Answers
5660
Questions
0
Helped
2194697
Points
18014
1) If the laptop is dirty inside that will sure do it.
If to your knowledge the laptop has never been cleaned inside, then it is.
The Processor and graphics chipset, are the two hardware components that give off the most heat.
Example of a laptop that is dirty inside.
Dell XPS M1710 used for example,
http://www.youtube.com/watch?v=AkAeE5I5E_A
Better idea of what you are looking at,
http://www.parts-people.com/index.php?action=item&id=3947
Click on image to enlarge.
1) To the left you see the rectangular finned Heatsink.
2) The curved copper Cooling Tube
3) The aluminum metal X-shaped plate, that sits on the CPU (Processor)
4) The small square shaped aluminum metal plate, that sits on the GPU.
(Graphics chipset - slang, proper term - Graphics Processing Unit;
http://en.wikipedia.org/wiki/GPU )
The narrator in the video is removing a 'lint blanket', from the fins of the Heatsink.
The Cooling Tube is a slightly flattened copper tube, sealed on both ends, and filled with Nitrogen.
The aluminum metal plates that sit on the CPU and GPU, absorb heat from them.
The Cooling Tube absorbs the heat, then transfers it up to the finned Heatsink.
The Heatsink absorbs the heat, then radiates it away with it's Tall, Thin, fins.
Air flow from the Fan Assembly helps carry heat away from the fins of the Heatsink.
Example of Fan Assembly,
http://www.parts-people.com/index.php?action=item&id=3059
The side on the right, goes against the finned Heatsink.
Air is drawn up through the center, then comes out the straight side of that D-shaped fan shroud.
Fan in photo is clocked 90 degrees to the Right, to how it actually sits on the laptop.
When the GPU (Graphics chipset), overheats; videos and frame rates seriously slow down.
When a CPU (Processor) overheats it turns off. (BIOS turns it off)
This is a fail safe feature built-in. Keeps the CPU from burning up.
ALSO;
Thermal Paste, or a Thermal Pad is used for the CPU, and GPU.
Generally the CPU uses Thermal Paste, but not always the case.
Thermal Pads are used too.
Most of the time a Thermal Pad is used on the GPU.
The top of a Processor, and the top of a Graphics chipset, are NOT perfectly smooth.
A magnified view would detail, 'Hills, Valleys, and Pitholes'.
Same thing with the bottom of the two aluminum metal plates, that sit on the CPU, and GPU.
Mated together there are air pockets that are created.
Air is an Insulator. Thermal Paste is a Conductor.
Excellent conductor of heat, and fills the above stated imperfections.
A Thermal Pad is a material that is impregnated with Thermal Paste.
(Usual size about 1 Inch by 1 Inch, and 1/16th Inch thick.
[25.4mm by 24.5mm, and 1.524mm thick]
If a Thermal Pad is used, carefully peel it off, throw away.
They're junk, and can't be reused anyway.
Most of the time however, they are needed for the GPU.
The distance between the top of the GPU, and the metal plate on the Cooling Tube; requires this thickness.
NOT this kid.
I find a suitable small piece of copper sheet, and the correct thickness. Then I apply Thermal Paste (PROPERLY), to the top of the GPU, and the bottom of the metal plate.
I also use a piece large enough so that more heat is dissipated, then with that small square of aluminum. (That sits on the GPU)
More surface area = better heat dissipation.
!O_O!
Observe what this tech has done, as far as increasing surface area; and you'll know what I mean,
http://www.youtube.com/watch?v=bnkQNmKauEc
http://www.hardwaresecrets.com/article/274
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3829122&CatId=503
State the model number of the Acer laptop in a Coment.
This is on the bottom of the laptop.
Perhaps I can find a link to a free Service Manual, and maybe a pictorial disassembly guide.
I can also guide you if you wish.
2) If it's videos on the internet, make sure your Java is up to date, and your Adobe Flash Player.
If you stated your laptop just stalled on certain intense games, I would have stated your GPU isn't good enough to run them.
Post back in a Comment.
Regards,
joecoolvette
max carson
Level 3:
  • Acer Master 7,627 Answers
max carson
Acer Master
Level 3:
Answers
7627
Questions
Helped
1015211
Points
21773
Open the Task Manager, click on the Performance tab, is your CPU running at or near 100% while the Media Player is playing the video? If so, you may have to many open/running programs. Running a Media Player requires more Processor and Memory. What Media Player are you using? Are you viewing the video on-line? You didn't supply the Acer model or the OS you are using?
99 bravado stalls after it gets warm . Drive about 20 miles and dies. Starts again when cools down.
What's missing after it stalls ? Spark , fuel pressure etc.... Find the system with the problem an diagnose from there ! An ignition control module , engine sensor ,engine computer . Anything electrical that when heated up fails internally .Videos on youtube showing how to test for spark and fuel pressure .
1987 olds cutlass ciera stalls while driving and then stalls when restarted and put into gear
Could be anything from description, please add more detail
Has the fuel supply system been checked over, it could be any element/compnent on the pathe between tank and combustion chamber plus all the peripheral components in the chain,
Has there been any othe associated bad behaviour. Anything more that might give a clue.
Any smoke?
2005 Jeep Grand Cherokee I get a trouble code po884 what could be the problem it stall at idle at times not always 5.7 hemi 4x4
the second digit is a xero not an O
visit link below for more information.
if you are doing a web search enter the code correctly for better results
P0884 code and stalling JeepForum com
1helpful
Lately my BMW Z3 Roadster will stall at traffic lights. It has even stalled when I am driving very slow. Sometimes the engine shudders when idle. I have also experienced the engine stalling for a second...
What have you checked, if anything? Have you noticed anything strange about idling (higher or lower than normal)? It could be many things, from something as simple as a dirty air filter, not allowing in enough air to the engine, to something wrong with the fuel pump. A vacuum leak is another possibility.
1helpful
Stalling and Check engine light is on. Tail pipe rusted of Muffler this week, Would that have anytihng to do with it stalling?
Really,come on, No ---- the tail pipe wouldn't have anything to do with stalling.
If there were exhaust leaks before the O2 Sensor it wouldn't help any
3helpful
2001 Saturn SC2 that randomly dies out without warning. All of the electric inside works and there is no stalling or anything before the vehicle shuts off. Has error codes PO340 and PO405.
2helpful
My N64 freezes up after a few minutes of play is there anything I can do or is there someone or somewhere that will fix it
Well maybe the console needs to be cleaned out then dust causes video game consoles to over heat 10 times faster than their normal rates because it acts like a barricade for the system. Or if the voltage is off it can cause stalling or it the ac adapter isnt putting out the right connection for the console it will freeze. Clean out the gamepacks with rubbing alcohal and qutips too.
Speeding up utube videos in windows vista
The speed of playback of online videos is affected by several factors: 1. The actual download speed of your broadband connection (no broadband? only videos that can be downloaded to your hard drive can be played, after complete download)
2. The speed of the processor in your PC. Anything made in the last two or three years should handle it.
3. The video adapter chipset used. Again, anything made in the last two or three years should handle it.
Operating system, i.e. Vista, has little to do with playback speed, although a resource "hungry" OS like Vista could stall if you have too little RAM. Note that 4GB RAM is the maximum practical unless you have a 64-bit computer with a 64-bit operating system
3answers
Stalls while Driving
that'll b air intake system or not enough gas going 2 the engine so it stalls or blocked gas lines
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
