Magic Sing Along Consumer Microphone Logo
Question about Magic Sing Along Consumer Microphone
How to connect the magic sing to a smart tv 8000 series?
M.Eldine De Angel
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
How do you connect a magic sing with red/white/yellow cable to a samsung 4k ultra hd 800 series which only has a hdmi cable
Posted on Dec 20, 2017
4 Related Answers
Anonymous
SOURCE: My magic sing karaoke ed 8000
My frined take it back to her counrty Where she brought it
Posted on Jul 30, 2008
Anonymous
  • 6966 Answers
SOURCE: Won't turn on
Two possibilities other than those posted:
  1. defective/corroded battery contacts/wiring. It may be needed to clean/scrape or bend/stretch the battery contacts to provide more pressure to the batteries;
  2. defective on/off switch.
Both are relatively easy to repair but of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 04, 2008
Anonymous
SOURCE: Magic Sing EG-18000 Microphone Delay
i bought et18k. just the same as yours.its 2 days old and has the same problem. the technical assistant says that its because of the digital setting that new tvs have. there are two ways to solve this though:
1. connect the video (yellow plug) to the tv. and the other two plugs (yellow and white) to the stereo. when i say stereo, its not the dvd home theater system that you have but a separate one. if you connect it to the home theater that you have, it'll just sound the same, you still have the delay.
2. connect the magic sing to the older tvs hangin out. and you'll get no problem at all.
**TVs such as sony, samsung, philips, sharp and all plasma tvs including other newly designed tvs will have the delay since they all share the HDMI thingy that causes sh*t.
Posted on Sep 17, 2009
criss_michae
Cameron Lewis
  • 64 Answers
SOURCE: magic sing ET18K delay problem
The instruction manual should have a calibration section. If not, you can probably find the instructions at the manufacturer's website.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Posted on Feb 11, 2011
How to connect enter tech model ls 3700T karaoke to tv
connect the RCA-cable to the TV one by one;
yellow (video),
white and red (audio).
Change the TV mode to "AV" or "Video" after
the magic sing is turned on.
1helpful
Magic sing ET18K delay problem with my samsung 8000 LED TV 3D. please help!!!
Hope that helps!
3helpful
I have connected the Magic Sing to a HD TV and a home theatre system and now get a sound-lag between the voice and the sound on the home theatre. Any ideas?
You need to connect directly the sound wire of your magic sing to your home theather while the video wire of your magic sing directly to your hdtv. If its difficult to do because of distance, buy an rca extension to extend your magic sing wire to make it reach to the other end.
5helpful
3answers
2-second delay with Magic Sing
3helpful
Change from PAL to NTSC
You need to configure it out.
1. Connect the magic sing in your TV
2. Turn on your TV
3. Magic sing should be Off
4. On your magic sing; Press and Hold "8" then while holding "8" press "power button", count for thre seconds then release both buttons (PAL to NTSC)
or
On your magic sing; Press and Hold "9" then while holding "9" press "power button", count for thre seconds then release both buttons (NTSC to PAL)
7helpful
7answers
ED-8000.
You can not because the songs are in different format. the only thing that you can do is to use recording chip, insert in magic sing, record some songs or record your singing then upload it in your PC using the download manager CD and USB cable
the unit comes with a cd download manager (window XP) and a USB cable. the you can uploaaad your recorded songs in your PC.
Top Magic Audio Players & Recorders Experts
W.L.
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
