Question about Konica Minolta DiMAGE A200 Digital Camera
Minolta Dimage A200 Disassembly instructions - Konica Minolta DiMAGE A200 Digital Camera
5 Related Answers
Anonymous
  • 425 Answers
SOURCE: Is it possible to control DiMAGE A200 from PC? (when DiMAGE A200 is connected to PC.)
No, the camera cannot be controlled from the computer.
Posted on Sep 15, 2005
Anonymous
  • 3 Answers
SOURCE: how to the the standard lens off my konica minolta dimage a200
Sorry, the lens is fixed onto this camera. It's not possible to change it.
BUT there is a solution; you can but a small lens to screw into the front of the existing lens like a filter.
There is one to get better close ups (super macro I s'pose) and another to get better telephoto.
There's a page about them in the hand book somewhere near the back. Gives the Konika part numbres and so on.
Posted on Mar 02, 2009
Ty Price
  • 11967 Answers
SOURCE: My Konica Minolta Dimage A200 do no recognize the
Format the cards in the camera. Make sure you download any pictures that might be on the cards first. Use a card reader if necessary.
Posted on Oct 12, 2009
rommelalilin
Rommel Alilin
  • 2178 Answers
SOURCE: I dropped my konica minolta
The tracking servo motors and associated gears are damaged or misaligned. The purpose of these servos are to automatically adjust the lens positioning so that it seems the camera is almost stationary. When the anti shake is enabled, the lens locks onto a target and if the target moves, the servos move the lens to compensate for the offset. If you are experiencing screen shaking it means that the lens is trying to adjust but cannot because the servo system is damaged. It's quite possible that only one servo motor is functioning and the other is loose. It will require in shop repair.
Posted on Nov 10, 2010
NoOperation
J?rgen S?derlund
  • 7 Answers
SOURCE: I have a Konica Minolta Dimage A200. The memory
If the pins aren't bent to bad, there are a chance that you could take the camera to a repairshop and ask them to either replace or bend back those pins that has been bent. A bit of warning i can be expensive due to the fact there are great deal of screws needed to be removed and several cables needs to be extracted from the cpu board, tough the expansionslot connector is located beneath the cpu board. It took me about 30minutes to disassemble the camera entirely so it's possible to repair the flash card pin connector. And about the same time to reassemble the camera.
Posted on Jan 25, 2013
I can be fixed, but will be expensive. Get a local quote.
Mar 24, 2010 | Konica Minolta DiMAGE A200 Digital Camera
HI i need the manual for my konica minolta dimage a2 thank you
Good Afternoon,
Because Konica Minolta no longer exists in the photographic industry, many of their support channels have been filtered over to Sony Corporation, who was the purchasing agent of their photography division.
Below is a link to where you can download an English manual for your DiMage A2:
http://ca.konicaminolta.com/support/manuals/digital_cameras/dimage-a/index.html
And the one you want can be followed to this link:
http://ca.konicaminolta.com/support/manuals/digital_cameras/dimage-a/dimage_a2/D_A2_E.pdf
or you can simply click on it from the first URL provided.
Hope this helps!
Lompanow
Feb 10, 2010 | Konica Minolta DiMAGE A200 Digital Camera
My Konica Minolta Dimage A200 do no recognize the memory cards. Can anybody help e to solve this problem?
Oct 12, 2009 | Konica Minolta DiMAGE A200 Digital Camera
Suitable compact disk memory card for dimage a200
I have the same camera. It will use up to a 4GB card as standard and up to 8GB with the correct firmware.
Check the following web address for further information: -
http://ca.konicaminolta.com/support/americas/digital_cameras/dimage-a/dimage-a200/software_drivers/firmware/installation_guide.html
I hope you find that my answer has helped, if so please return the favour by rating my answer.
Jul 21, 2009 | Konica Minolta DiMAGE A200 Digital Camera
Disassembly lens konica minolta Z3 Z5 Z6
I think the manual of this sort are not available to the general public or indeed the 'trade'
You will have to grope your way if you want to play those games
Feb 23, 2008 | Konica Minolta DiMAGE Z3 Digital Camera
How can I get the firmware for utilizing the telephoto converter / wide-angle converter
The firmware for telephoto converter/ wide-angle converter is included in the attached CD-ROM. Please update it if you have DiMAGE series 7i to A1. Please confirm the firmware version and update it if you have DiMAGE A2 and its version is 1.10. DiMAGE A200 users do not need the firmware updating.
Sep 15, 2005 | Konica Minolta DiMAGE A200 Digital Camera
What are the available ISO rating for the DiMAGE A200?
The DiMAGE A200 sensitivity can be set to Auto, ISO 50, 100, 200, 400, and 800. When Auto is selected, the camera automatically controls the sensitivity within the range of ISO 50-200.
Is the DiMAGE A200 equipped with AF illuminator?
No, it is not. But the camera can automatically balance the CCD sensitivity to enable autofocus even in low-light condition.
Konica Minolta DiMAGE A200 Digital Camera Logo
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Sheldon Dedek
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
