I have tried plugging it in to the car and to the computer. When it is plugged in, it gives no indication that it is plugged in or charging like it usually does. It will not turn on at all. The only solution I have found on the internet is to reset it, BUT, I cannot find a reset button on it anywhere! I even peeled off the serial number sticker and looked under there, but there is only two little screws. Another solution I read was to remove the battery, which I assume I have to take out the little screws to do, but they are not normal screws, neither a flat or philips tiny screwdriver fits in it! I just moved out of state from MD to FL and I need my GPS to work! I have no idea where I am going lol. Please help!
SOURCE: GPS would not turn on
Download the manual and find the reset button..it should start right up.
SOURCE: Garmin won't charge or turn on.
Hello :
How old is your battery ? I think that the battery life is ended [ can't be recharged anymore ] . Just replace it and problem will be solved .
please rate !
SOURCE: I have a garmin nuvi
Hi Kyair06,
You can do a hard reset of your unit by sliding the POWER switch to the ON/OFF position and holding for 10-15 seconds. The manual says 8 seconds, but it won't hurt to do it longer. If everything is ok, it should come back from the dead.
In case you don't have the manual, you can download one here:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
When you get the unit going again, you may want to do a software or firmware update. The Appendix around page 41 will tell you how.
I hope this helps. Let me know if I can be of further assistance. Thanks.
Regards, Bill
SOURCE: I just received my neww 1450LM Garmin Nuvi GPS
Garmin is voluntarily recalling certain nuvi devices that contain a
specific battery that was manufactured by a third-party supplier within a
limited date code range.
Garmin has identified potential
overheating issues with the use of these batteries in certain nuvi
devices with a specific printed circuit board (PCB) design. Additional
information about the nuvi battery PCB recall can be found in Service Alert Number: 1035.
The
models that may be impacted by the nuvi battery PCB recall are the
200W, 250W, 260W, 7xx and 7xxT (where xx is a two-digit number). To
determine if your unit is affected, please visit www.garmin.com/nuvibatterypcbrecall
and enter your nuvi's serial number. If your unit has the specific PCB
design and contains a battery from the specific date range, you will be
given instructions on how to return your nuvi for a battery replacement
at no charge.
You should not attempt to remove or service the
battery on your own; all battery replacements must be serviced through
Garmin's authorized service provider.
If you do not have web access, you may contact Garmin through one of the phone numbers below:
Repair
time will vary based upon location. U.S. customers, please allow 10-16
business days to receive your repaired or replacement device. Canadian
customers, due to increased shipping and customs clearance times, please
allow 20-30 business days to receive your repaired or replacement
device.
Garmin sincerely regrets the inconvenience that this
recall has caused and is making every effort to cooperate with
customers, dealers, and regulatory agencies worldwide to ensure all
parties are assisted according to national regulatory standards
Is it possible that the battery is just completely dead? I did buy it in 2011, but have only really used it maybe 15 times since then until 3 weeks ago when I moved to FL.
