Question about GE Washing Machines
GE WASHER BELT TOP \DSR LOAD WHDSR316G1WW
NEW BELT, CANNOT GET IT ON. TO TIGHT. WHDSR316G1WW 2008 HYDRO TOP LOAD WASHER. HOW CAN I GET BELT BACK ON
Posted by lorrishere on
nate nixon
    New Friend:
  • 104 Answers
Put the belt on the motor pulley then start with the other end on the drum pulley and turn it with your hand , i hope this makes sense . the object is to let the pulley do the work of stretching the belt into position
Posted on Feb 25, 2013
5 Related Answers
Anonymous
SOURCE: GE WDSR2080D5WW Top Load Washer
I have the same unit, about 3 yrs old. The problem I have seems to be the air switch that controls the water level. It also controls the spin cycle by telling the timer unit that the tub is empty and ready for spinning. Either the hose is clogged or the pressure unit glued to the tub is clogged. I hoper that helped! Good Luck!
Posted on Oct 26, 2008
Anonymous
SOURCE: removing cover assembly on GE top load washer
Is your washer a GE Profile Harmony? Do you want to know how to take the top off or the top of the agitor (pulsator)? The top of the washer has four screws in the back top behind the screen once you unscrew them the front of the washer has two clips one on each side and you have to kinda tap it with your palm to get them to pop.
Posted on Jan 13, 2009
Anonymous
SOURCE: My ge hydro wash washer model WHDSR316G1WW will
for model: WHDSR316G1WW General Electric Washing Machine
Unplug the machine at least 30 seconds
Turn the dial to the spin cycle, but do NOT pull it out yet.
Plug the machine back in and then lift and close the lid 11 times within 15 seconds and finally pull the knob to start the washer on spin cycle.
This should clear the error code.
GE service 1-800-626-2000 (option 3)
Posted on Jul 13, 2009
FixinFax
Leroy Elliott
  • 3085 Answers
SOURCE: GE WBSR3140DW Top Load Washer Repair manual
Check your local Appliance Parts Stores, they usually have racks of repair manuals.
Posted on Nov 25, 2009
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: my washer won't agitate or spin! I hav a GE washer
Might be a blown line fuse located in the red and white wire in the harness, you will know it if the green idiot light on the motor ain't a blinkin.
Got questions? I will be here all week.
Rate the answer and thanks fer using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 13, 2010
Banging noise comming from back of washer near the belt
I have a GE WHDSR316G1WW top loading washer and the drain hose located on the upper left rear of the plastic outer tub came loose. It sounded like a worn seal or bearing because it was banging so loud. I removed the control panel, top panel and front panel, reattached the drain hose into the housing hole and the problem was solved. Saved $80 service call.
Aug 15, 2013 | Kenmore 24032\24036 Top Load Washer
My GE whdsr316g1ww will freezes during the 'Cottons' cycle
please see the next step and use the common sense: God bless you
Lid Switch
This is the most common reason for the washer not spinning or agitating. This is easy to check. You will need to remove the switch, this varies with model type but the testing will be the same. When the lid is closed the switch should have continuity when the lid is opend the switch should have no continuity. If it differs replace the Lid Switch.
Timer
To check the timer you will need to refer to the wiring diagram or disassemble to access the motor. Check the leads from the timer to the motor when turned to a wash cycle this should have 120 volts. If not replace the Timer, if it does the timer is not the problem.
Motor
To check the motor you will need to disassemble the washer to access the motor. First you can check the motor windings, to do this remove the plug and connect ohmeter to terminals. Refer to the tech sheet or service manual for the proper reading. Check motor for shorts by connecting ohmeter to terminals and motor housing should have no continuity. Connect voltmeter to motor wire connector and check for voltage. You should have 120 volts, if you do and the motor does not run replace the motor. If it does not have power the problem is elsewhere.
Belt
If your washer is a belt drive type make sure the belt is tight. Check for black soot from belt wear. Replace if it has excessive wear or broke.
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacement of the Motor Coupler.
Transmission
The transmission does not usually fail. To check this on a direct drive remove the motor and then turn tub inside. If it spins freely with no noise the problem is elsewhere. If it is noisy it needs replacing this is expensive and depending on the age of your machine you may not want to replace it. On a belt drive remove the belts and spin tub
Aug 01, 2012 | GE WBSR3140DW Top Load Washer
Whdsr316g1ww
ther shoot be 1 in the concel try to open it and look inside ge is good to put 1 ther ther not. the only 1 the can get on is ge try caling the the # is 800-gecears
Feb 21, 2012 | GE WBSR3140DW Top Load Washer
I have a GE washer WHDSR316G1WW and I cannot get a new belt installed. How do you install the new belt? It barely fits around the large pulley.
You are correct in that the belt seems overly tight. This is what I did.1) Get the belt on the large pully2) Using several ZIpTies every few inches, secure the belt to the pully3) Get a metal hanger and loop it through the belt making a safe handle at the end.4 Cover the handle with a cloth to protect your hands and to also provide grip.5) Have my 300 lb, 6'7" hulk of a son pull as hard as he can while you assist getting the belt on the motor spindle.
Sep 13, 2011 | General Electric WHDSR316G Top Load Washer
My washer won't agitate or spin! I hav a GE washer model # whdsr316g1ww
Mar 13, 2010 | General Electric WHDSR316G Top Load Washer
Cannot get drive belt on ge washer model #whdsr316g1ww
I have a front load kenmore washer. Initially the machine didn't drain the clothes fully, then the belt came off. The belt will not stay on. Help
Feb 25, 2010 | Washing Machines
Doesnt agitate or spin.
Mine is 1 1/2 years old and this worked for me
unplug from power for at least 30 seconds
turn the dial to spin but don't pull out
plug back in to power and open and shut completely so switch is engaged solidly 11 times in 15 seconds.
pull out knob to turn on
This should clear a error code.
hope it helps!
Jun 02, 2009 | General Electric WHDSR316G Top Load Washer
My ge hydro wash washer model WHDSR316G1WW will not spin or agitate. It did this same thing a couple of months after I bouht it, the serviceman said the belt was off. I've checked the belt and it seems to...
Apr 23, 2009 | GE Washing Machines
No spin or agatae
Unplug machine. Change load type to medium. Clean door sensor. Set knob to drain and spin. Plug machine back in to powr. Open and close door 10 times in 15 seconds. Pull knob to activate drain and spin.
Mar 19, 2009 | General Electric WHDSR316G Top Load Washer
Loud draining
hello mam please clean the drain filter and check the noise if you feel the same then please change the drain pump.
Mar 01, 2009 | General Electric WHDSR316G Top Load Washer
Washing Machines Logo
85 people viewed this question
Top GE Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Mike
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
