Flickering 10"cobykyrosinternettablet
Posted by Gloria on
Brian Sullivan
  • Computers & ... Master
  • 27,725 Answers
Step 1:
An inverter is an electrical device on the bottom of your laptop screen. The job of the inverter is to convert DC electrical current to AC voltage to maintain power to the backlight lamp. If the display on your laptop is dark but working, odds are the inverter or the lamp are at fault. When troubleshooting monitor problems on a laptop, you may need to evaluate the inverter to determine which of the two parts is malfunctioning.
Remove the screen bezel on your laptop. The bezel is the piece of the computer casing that surrounds and protects the LCD screen. To remove the bezel, remove the screws around the screen. Bezel removal method may vary by model. Once the screws come out, the bezel should pop off. The inverter will be under the screen. Attach the positive probe (+) of a multimeter to the pin 1 on the inverter. The inverter has two connections, one on each end. With the laptop screen facing you, look at the left side of the inverter. Pin 1 is the top metal flange pointing to the right. Secure the negative probe (-) of the multimeter to any bare screw. There should be a screw securing the inverter to the laptop that will be perfect for the negative ground connection. Turn the laptop on to test the inverter. Turn the multimeter on and check the multimeter reading. If the display records voltage going to the inverter, such as 19 V DC, the inverter power supply is working. Turn the laptop off. Unplug the LCD inverter connection on the right side of the inverter. This disconnects the backlight from the inverter. Plug a working backlight to the connection on the right side of the inverter. Turn on the laptop. If the screen lights up, the backlight lamp is bad but the inverter works. If the screen remains dark, the inverter is bad.
b>
Posted on Feb 25, 2013
Polariod tlx-04240b is flickering
There is adjustment to stop the flickering. But, you have to enter its service mode option do do this. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 17, 2014 | Televison & Video
Lights flicker
check ground locations in harness under hood ,make sure they are tight
Mar 04, 2013 | 2001 Dodge Dakota
How to lock through a password
push light key for 10 seconds when led flickers enter 10 press start enter 1 press start.shot down.push ligt for 10 seconds flickers,enter 11 pres start enter code(example 123)start .repeat (123)start,
Apr 22, 2010 | Sharp AR-5316 Advanced Digital Imager...
36 inch tube tv - Screen flickers
my problem is don't sound in my mobile LG CE 0168 please help me.
Aug 17, 2009 | Toshiba Televison & Video
Dell 2005FPW Monitor Flicker problem
The flickering is most likely the florescent backlight having a hard time starting, Just like in a light fixture, as it gets old, it takes longer to warm up to get full functionality.
If under warranty, contact Dell for a replacement, if not, then when it becomes untenable, replace the monitor. Prices are dropping drastically, an new 20 or 22 In can be bought for about $150 or less
Aug 08, 2009 | Computers & Internet
RCA W40D20 HDTV intermittent flicker and it gets blurry
loose connection on ends check you hdmi cable vga cable and vgi cable so the pins are good or not bent try to borrow another and see if it changes it and dont go to far from your tuner .
Apr 21, 2009 | RCA Scenium D40W20 40" Rear Projection...
No power - 10 flickering red lights ?
try looking at the board inside the TV for bulged capacitors see polaroid thread. this is the problem on the polaroid could be the same here. tips and tricks section
Sep 16, 2008 | Panasonic Televison & Video
Computers & Internet Logo
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
