Check your temp probe ans see if it is not up against the wall or jammed of even broken off.
Posted on Feb 24, 2013
SOURCE: Temp probe indicator stays on
If you’ve accidentally switched the oven control on your GE oven from Fahrenheit to Celsius (or vice versa), it can seem like an oven control problem; the keypad will accept some temperature selections and not others. Easy enough to switch back to the way you want it– this excerpt from your owner’s manual explains the technique:
Your oven control is set to use the Fahrenheit
temperature selections but you may change this
to use the Celsius selections.
Press the BAKE and BROIL HI/LO
pads (on double oven models use
the upper oven controls) at the same
time for 3 seconds until the display
shows SF.
Press the BROIL HI/LO pad. The
display will show F (Fahrenheit).
Press the BROIL HI/LO pad again. The
display will show C (Celsius).
Press the START pad.
NOTE: On double oven models the new setting
will be displayed for both ovens.
Posted on Feb 13, 2008
SOURCE: DCS double wall oven model WOSD 230 totally dead during first self clean
let me know if you don't get the solution... thanks
Posted on Sep 28, 2008
SOURCE: Dim LCD's on DCS Double Wall Oven
Had the same problem last week - called DCS (which automatically transferred me to Fischer-Paykel) and was able to order the part from them. They knew exactly what it was, and shipped to me in CA from CA, it was less than $90. Just installed it, and the new one works swell. One suggestion - I drew with a Sharpie on one side of each of the three parts that plug into the board to help align the new one, and to install the wide ribbon cable (not really a cable, but you'll know what I mean), pull up on the two side pieces and the ribbon pulls right out. Keep it up and slide the new one in and then push the black piece down. That was the only part that took me a minute to figure out.
Posted on Oct 04, 2008
SOURCE: F7 error message in DCS 27in double electric oven
hello. here is the customer service department info at DCS. Since this unis is new, Irecommend that you work directly with them so as to avoid voiding the warranty
http://www.dcsranges.com/contact.html
Posted on Jun 22, 2009
SOURCE: dcs oven display dim - need part #
I just did this same repair...same part number as above (Part #211696 "Electronic Oven Control, Double).
to install you have to remove two screws on the top of the display section of the oven, as well as several screws on the bottom of it, and the screws holding the close pin/temperature probe socket.
Then you can pull off the whole top section (slowly) and remove the two connectors to the existing control unit.
Then release the ribbon cable connected to the control unit on the inside of the top section (press the two small pins inward and slide up the small front section of the black socket to release the ribbon connector.
Unscrew the old control panel, screw in the new one, connect the ribbon, and then reverse removal steps. Easy!
Posted on Jan 21, 2010
