Question about Panasonic SC-HT900 System
There's no sound in the back speakers just the two front ones
Posted by houstontxroc on
Vsx-815 sb. system
Check in your speaker setup menu. Sometimes you can select between using the surround back speaker jacks as "B" front speakers as well. You would have to tell the unit which one you want to use it as.
Feb 08, 2013 | Audio Players & Recorders
Low sound output from Front Speakers
The out put transisters are probally fried for the front channels,
Nov 27, 2012 | Sony STR-DE695 Digital Audio/Video Control...
Front inputs? (green and pink not working)
I thought the front was for a microphone and headset. I don't think those are speaker jacks. Look closely at the icon that is next to the pink and green on the front, does it show the icon of a microphone and headset?
Normally the speaker jack will show and arrow going out which means sound going out. If you look at the speaker port in the back of the computer it is normally the light green port. Notice the icon on it. Does the icon on the front look the same as the one on the back? Is the color on the front the same as the one on the back? I think you're plugging into the wrong port.
Make sure you have the volume up in your Audio/Sound properties and make sure you don't have the speakers on mute. Also make sure you turn the speakers on and turn the volume up on them.
Mar 04, 2012 | ASUS Computers & Internet
How do i set up my subwoofer sawm40
Sounds like you have a passive subwoofer, you run speaker wire from 'front speaker receiver out' to the subwoofer, the 'subwoofer out' to your front speakers. Seem like your sub has a crossover that grabs the bass frequencies and passes off the rest to the front speakers
If you have a 'subwoofer line out' on your reciever and a 'line in' on you subwoofer then just use that single wire, this would be for a powered sub. You know that you have a powered sub if your sub has a power cord attached to it.
Jan 23, 2012 | Sony Audio Players & Recorders
What are your fees?
what do you mean our fees, for what part is your question
Aug 11, 2011 | Denon AVR-2801 Receiver
I have a set of logitech X-530 speaker for my computer with windows home 7, i have had the front left and front right speaker working properly, however now i cannot get any sound from any of the...
Try to disconnect the input connector of your speaker and touch the input jack of the unit if you hear a hazing sound it means your speakers are working properly but if you don't hear any sound your speakers are bad. Open the speaker unit and check the amplifier section of your unit. If you don't see any burned electronic component inside. Check the wiring of your unit.
To check if the audio of your computer is working. Plug in the input a headset if you hear a sound while you playing a music in your computer it means the audio of your computer is working good.
Jul 12, 2011 | Logitech X-530 Computer Speakers
I don't know which port in the back of the Pavilion to connect the black wire from the speakers (that connect to the right speaker with red and white ends). Any ideas? They are labeled as side, rear...
To get "surround" sound, when you face the computer, you will have:
* 2 front speakers, one immediately on each side of the computer
* 2 side speakers, one on each side of your head
* 2 rear speakers, one behind each side of your head
Thus, when the sound is of a jet-plane coming towards your face,
you'll first hear the sound in the front speakers,
then in the side speakers,
and finally in the rear speakers,
to produce a sound-effect of the jet passing over your head, and going "behind" you.
Usually, for "front" speakers, one speaker connects to the other speaker, and the second speaker connects to the "FRONT-audio-output" connector on your sound-card.
For side speakers, one speaker will connect to the LEFT-side-audio-output port,
and one speaker will connect to the RIGHT-side-audio-output port.
For rear speakers, one speaker will connect to the LEFT-rear-audio-output port,
and one speaker will connect to the RIGHT-rear-audio-output port.
Jun 01, 2011 | Audio Players & Recorders
Rear speakers on a 99 bmw sound low
I'm guessing you mean that the back speakers are more quiet than the fronts? On most audio receivers there is a fade option, meaning that you can have only the fronts working, the backs, or anywhere in between. You may want to check the owners manual and find that option, I'm guessing that is what is causing the problem.
May 05, 2011 | Car Audio & Video
Put in new front speaker in car and they worked good for a couple of hours, now there is no sound from the front or back speakers. I unhooked the front speakers and put one back then rear speakers worked...
Hello. Sounds like the amplifier is damaged and or could be a short from a front speaker wire to the car chassie ground. Assuming that the four speakers are driven by the same deck. I would first varify that the amplifier in the deck (radio, CD, etc) is functioning properly if it is being used.
Jan 21, 2009 | Car Audio & Video
Panasonic SC-HT900 System Logo
Top Panasonic Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
