I had the monsoon stereo removed in my 2004 pontiac Grand AM and installed a Kenwwod system at best buy. However the system kept jumping from the radio station over to bluetooth and giving me an Audio disconnect message. I found that keeping the headlights and fog lights on prevented it from happening, who would guess? Anyway I got tired of it acting that way and replaced it with an Apine. Now I am having trouble with it acting up. Is there something you have to do when replacing the Moonsoon that I or the Geek Squad doesn't know. This is getting very frustrating as I have had the car back 5 times now and can't get anything to work correctly. Is there a special way that it has to be wired?
SOURCE: no sounds from stereo
sounds like that is the problem i think that you need a special harness go to this website: metraonline.com and look up your vehicle you should be able to find the harness at bestbuy or a car stereo shop not sure how much it could be. May be expensive.....
SOURCE: how to fix a 821 EONON car stereo
you could just try disconnecting power overnight and see if it resets then. sometimes pushing reset doesn't always completely clear the memory.
SOURCE: Where do I locate radio fuse on 2003 VW Golf Fuse Block?
#42 (25 amp)
Source(s):
http://forums.tdiclub.com/showthread.php?t=122606
SOURCE: My eclipse stereo is in lockdown-anti theft mode & can't unlock
contact the dealer of your car, give the vin no:of your car to them, and they will be able to give you the radio code
SOURCE: Im doing an aftermarket sub and amp installation
Use the connector on the back of the radio to get your signal source.
diagram is located here http://www.modifiedlife.com/2003-volkswagen-jetta-car-stereo-wiring-schematic-for-monsoon-audio/
