How many times do this standby LED blinks at a time of switch on? These are fault indications. From the number of these blinks, you can get an idea about the faulty circuit section inside. These are called blinking codes. Count it. If you wish to get more details about the blinking codes to Sony TVs, check this link.
Posted on Feb 24, 2013
SOURCE: 2000 Sony Trinatron #KV-36FV26
IF--- You have 3 video ics located on CRT broad # TDA6111Q ,if only one of them is shorted set will not come on these ics will kill the high voltage, there for keeping set off.
Posted on May 19, 2008
SOURCE: Sony shuts off after being turned on, stand by/timer light blinks
The blinking should be in a pattern of a count, pause, count. That is an indication of the problem circuit. Can you post that count please? That info will allow me to give you possible defective parts and costs for the repair.
Thanks,
Dan
Posted on Feb 18, 2009
SOURCE: TV turns off and the standing timer light blinks.
There is a timer option programmed into your set. Check the timer setting in menu, under advanced settings
Posted on Sep 17, 2009
SOURCE: SONY TV MODEL KV-27FS120 stand by light
if it is continous blinking.........then you have a faulty jungle IC IC301,shorted to ground,IK video path is defected,............ hope this helped
Posted on Feb 17, 2010
