Question about ION Audio Vinyl Recording Turntable
Just switched my needle on an ION Profile LP but no sound will come out of my speakers.
My needle broke so I ordered an ICt04rs and slid it where it was supposed to go. The actual needle is producing sound but nothing is coming from the output. All audio connections are good and the speaker power is on.
Posted by Ryan on
Grubhead
  • ION Audio Master
  • 5,700 Answers
Disconect the wires to the cartridge. With the amp on touch each wire one at a time with your finger. You should hear on Two wires a buzz- one for each channel. If you do then the cartridge has failed. If you don't then there's either a bad connection to your amp, or the magnetic cartridge pre-amp inside the amp has failed. This will not effect any other part of the amp.
Posted on Feb 25, 2013
2 Related Answers
Jma11
John
  • 140 Answers
SOURCE: LP audio recording seems to be at the wrong speed
1- The turntable is set to 45 rpm and the album is recorded at 33 rpm. Press the 33 rpm button the red light should come on turn the and be fine.
or
2- This turn table has a fast record mode where you can record a 33 rpm LP faster by spinning it at 45 rpm. If you are trying to use this mode you will have to make a software setting to tell the TTUSB10 digital converter program what mode you want to run.
Posted on Nov 29, 2008
Mark Compton
  • 378 Answers
SOURCE: not all of the sound/music is being transferred
have you checked the ion site for an updated driver?
Posted on Apr 22, 2011
Sound is too loud and distorted from my ION iTTUSB turntable
well turn the mixer down. sound has NOTHING to do with the turntable . unless your needle is broke or dirty.
Jun 14, 2011 | ION Audio iTTUSB Turntable
Not all of the sound/music is being transferred from the LP.Hard to explain, but its when the LP has sound coming out of each speaker independent of one another, only one side is coming out on the recorded...
I know this is an old post, an I dont' have a solution yet, but t seems the same problem as on my Ion USB recorder - One of the input channels is not working. Like you, I found one of my music tracks not plying right - there was only the instrumental and no vocal. When I experimented, and changed round the jacks on the cable coming from the turntable (red and white plugs), I then got only vocals and no instrumental. Obviously one of the input sockets on the USB recorder is no longer working (I already checked the turntable and cable itself by playing back he same track with both stereo channels through my amplifier). You can either get the item replaced if its still under guarantee, or fix it yourself, if you have the necessary skills, neither of which apply to me.
Apr 22, 2011 | ION Audio Vinyl Recording Turntable
I hooked up the ion LP Dock to an analogue amplifier (which is hooked up to my LCD tv and outputs the sound through some bookshelf speakers) via the Phono input connections as per the instruction manual...
"PHONO" is the only designated connection on a receiver that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
BUT, modern turntables like your come with their own preamplifiers, so they MUST be connected to a garden variety Line Level input like AUX (anything BUT Phono or it will overload).
http://www.needledoctor.com/Ion-LP-Dock-Turntable?sc=7&category=16189
"LP DOCK also has a line-level output for connecting to any home stereo with an AUX input"
As far as WHY your amplifier isn't making da music, that could be whole 'nother problem.
We'd need more details about it and the speakers to go there.
Feb 27, 2011 | Universal Electronics Ion LPDOCK USB...
Hello, Does anyone know how to take the platter of an Ion Profile LP?
YOU MUST UNLOCK THE INSIDE AND THE TOP LOCKING RIGHT ... IT IS VERY SMALL TO SEE. IT IS THE ONE HOLDING IT ON TOP.. JUST TAKE IT OF THE CENTER PIECE. IF YOU HAVE TROUBLE..GET THE MANUAL AT WWW.TVPARTSANDMANUALS.COM AND FOLLOW INSTRUCTIONS
Jan 12, 2011 | ION Audio Vinyl Recording Turntable
THERE IS NO SOUND FROM MY PC WHEN I'M RECORDING MUSIC ON MY ION POWER PLAY LP..DO I NEED TO UPGRADE ITUNES?
i had the same problem at first, if you have anything other than a usb output to your speakers go into control panel/sound/change system sounds and disable usb speaker device.
Nov 27, 2010 | Computers & Internet
Ion profile pro -- recording picks up background sound
If you're picking up background (room) sounds the TT pickup is acting as a microphone. Isolate it physically from air- and room-borne vibrations. Turn your speakers down so they don't add to the problem, or use headphones while recording.
Feb 14, 2010 | Audio Players & Recorders
ION Audio Vinyl Recording Turntable Logo
140 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Marvin
Marvin
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
