We have a Zephyr hood with flush mounted halogen lights. I have been trying to replace a burned out bulb, but it seems stuck fast. Have tried to use the suction cup, but it won't budge. Could remove the good light without any problem. It seems like it's glued in. Any suggestons? I don't want to disassemble it unless absolutely necessary.
Hi elenara, try applying slight upward pressure as you turn the bulb. Remember righty tighty, lefty loosy. This worked for us, now if I could only find a replacement bulb. Good luck!
These Halogen bulbs are inefficient, and run so hot that they often damage the reflector and bulb socket if they are left on too long. Fortunately there is an easy fix for this. At most stores that sell the exact replacement Halogen bulbs (Lowes, Home Depot and others) you will see a selection of LED bulbs on the same display rack that will fit into the same socket the Halogen bulbs use. It is IMPORTANT that you know the code number stamped on the base of your Halogen bulb AND its voltage because some Halogen bulbs are 12 volts and some are 110 volts. If you can't read the labeling on the bulb, look for the wiring diagram usually glued inside the range hood or look in your owner's manual. Once you know your Halogen bulb's code number, look at the packages that the LED replacements come in. There will be a list of Halogen bulb code numbers that the LEDs are meant to replace. The male sockets on these LED replacements will be shaped just like the sockets on your original Halogen bulbs so they will plug in easily. However, just like LEDs bulbs that replace the old incandescent bulbs in your table lamps or ceiling sockets, they have an electronic section included in there base to run the LEDs and it makes the LED bulb slightly longer than the much simpler Halogen bulb. For my stove hood it meant that the bulb would not quite fit into the reflector in the hood. I had to use a Dremel tool to remove a bit of the reflector to get a proper fit. The LED bulb is just as bright but runs SO much cooler and uses so much less electricity that now I can use the range hood as a night light in the kitchen. I never felt safe doing that with the two Halogen bulbs since they ran so hot that they were burning the fixture that held them in the stainless steel hood and were melting the wiring entering the socket base. This upgrade to your range hood is well worth the effort.
These Halogen bulbs are inefficient, and run so hot that they often damage the reflector and bulb socket if they are left on too long. Fortunately there is an easy fix for this. At most stores that sell the exact replacement Halogen bulbs (Lowes, Home Depot and others) you will see a selection of LED bulbs on the same display rack that will fit into the same socket the Halogen bulbs use. It is IMPORTANT that you know the code number stamped on the base of your Halogen bulb AND its voltage because some Halogen bulbs are 12 volts and some are 110 volts. If you can't read the labeling on the bulb, look for the wiring diagram usually glued inside the range hood or look in your owner's manual. Once you know your Halogen bulb's code number, look at the packages that the LED replacements come in. There will be a list of Halogen bulb code numbers that the LEDs are meant to replace. The male sockets on these LED replacements will be shaped just like the sockets on your original Halogen bulbs so they will plug in easily. However, just like LEDs bulbs that replace the old incandescent bulbs in your table lamps or ceiling sockets, they have an electronic section included in there base to run the LEDs and it makes the LED bulb slightly longer than the much simpler Halogen bulb. For my stove hood it meant that the bulb would not quite fit into the reflector in the hood. I had to use a Dremel tool to remove a bit of the reflector to get a proper fit. The LED bulb runs SO much cooler and uses so much less electricity that now I can use the range hood as a night light in the kitchen. I never felt safe doing that with the two Halogen bulbs since they ran so hot that they were burning the fixture that held them in the stainless steel hood and were melting the wiring entering the socket base. This upgrade to your range hood is well worth the effort.
What model range hood do you have? To remove most of the bulbs from a Zephyr hood, wait for the bulb to cool after use. Then rotate the bulb counter-clockwise about 60 degrees (less than a quarter turn) and the bulb should drop down. If you have problems turning the bulb, try the glass suction cup that comes with the hood or a rubber/latex glove grip. Sometimes a rubber jar grip will also work.
The one way to find out your range hood bulb may be to remove one and look at the side/back. The bulbs are labeled. Otherwise, check your manual. Zephyr has the manuals for most of their ranges here: http://zephyronline.com/customer_support . Use the drop-down menu to select your model.
Different hoods use different bulbs. For AK6500, 6536, 6542 Cyclone hoods, purchase type: 4OR 14 mini flood light bulbs. For the AK2500, 2536 hoods, you need to purchase type GU 10 halogen bulbs. For the Anzio models, including the ZAN-E30AS, get a GU-10 50W halogen bulb.
Check out the zephyr Site. The halogen bulbs they use are very unique. Have two clients that have Zephyr hoods and took me a while to locate replacement bulbs. Could not find them at the local lighting stores nor hardware stores. I believe it is a 35 watt halogen (sort of an MR-16 size) with an entended base.
According to the "Use, Care and Installation Guide for your unit,
Replacement bulbs are available at
specialty lighting stores. Purchase type
JDR E27 50W halogen bulbs.
Or to order bulbs, please call our service
center: 888-880-8368 or online parts store:
www.zephyronline.com
The bulb is a JDRC E27. Google it and you will find various places to get it, such as BulbConnection.com or DivineLighting.com. I would recommend buying 3, because if one has gone, the other will go very soon (my experience) and then you have an extra in case you drop one or one of them fails soon. Shipping will be the same, so the more you buy, the cheaper the per-item shipping. Home Depot does not carry them. Also, I don't know the differrence between the JDRC and JDR, so if you get the JDR version you may be displeased. Also, before getting the LED types, check the brightness... when I bought mine, the LED's were not very potent, so I stuck with the Halogens. However, they are very warm.
