Pilot bearing (pressed into flywheel) or release bearing (presses against clutch pressure plate)?
Regardless, the repair is the same. Replace clutch disc, pressure plate, release bearing & pilot bearing. Most flywheels are available or as part of a complete kit, minimum is to inspect & resurface flywheel when replacing clutch assymbly.
Pilot bearing (pressed into flywheel) is collapsed (6202z) is the bearing number. got a full clutch kit but not with this bearing.got a quote for it £30 plus? vat (a bit steep) so had a luck in the shed and found one same make same numbers but for a yamaha ty175 that cost me only £6.75 anyway i will av a go tomorrow to remove the outer case of the bust bearing & fit the clutch.thanks larrysservic
i cant get the fly wheel off should it tap off
