Question about Raypak Rheem M8350ti-E, 130 BTU Digital Heat Pump
I have a rheem m8350ti-e pool/spa heat punp that runs but is not heating when i set up the tempersure
Fan turns on , control panel is light up ,i can change the tenpersure in the control panel. but it do't heat the pool.
Posted by hector ubinas on
5 Related Answers
joespools200
  • 246 Answers
SOURCE: Pool heater shuts off itself before the set temp is reached
need new board control kit
Posted on Aug 25, 2009
Anonymous
  • 40 Answers
SOURCE: Pool Not Heating Display Wrong
where the thermostat is located, the pump is not circulating the water
Posted on Sep 05, 2009
thepool
thepool
  • 78 Answers
SOURCE: i have a Raypak Digital Millivolt pool/spa htr which stopped heat
Don, I suspect the error message is the cause of your problems. A flow error is either real (low flow) or not (bad flow switch). Either way, you get the error code displayed. Always take the filter out of the equation first to make sure it's just not a dirty filter causing the issue. A sand filter can be placed in the "bypass" position or a filter cartridge could be removed. Restart the pump and see if the error code goes away. If it does, clogged filter, real flow problem. Clean / replace the filter. If it does not go away, locate the pressure switch, pull off the two leads and jump them together. If the code goes away, false problem, bad switch. Replace it. Rob
Posted on Apr 22, 2010
Heath Moyer
  • 767 Answers
SOURCE: I have a Raypac digital
Hello my name is Heath it will be my pleasure to assist you. Find the rollout switch and on the back there is a small red button if you push the button in it will reset the switch. The rollout is usually located near the burner section of the heater.I will attach a picture of a rollout switch which shows the small red button.11c0d2e.jpg
Posted on Oct 25, 2010
taran_2005
taran_2005
  • 10515 Answers
SOURCE: I have a Rheem pool
The heater only works when there is (FFL) Fluid Flow..through it, check the pump to see if its operating, then the line strainer to be sure its not clogged preventing water flow, then the flow switch, it may have stuck in the Low Flow position...Look all that over and get back to me. we keep going until we sort it out.
Let me know, so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 07, 2011
How do I get my GL235 Solar Heating Panel (Goldline Controls) to heat. It is not heating the pool even though the control lights indicate that the heater is on.
If water is flowing thru the panels/collectors, (look to see if the valves are opened to allow water to the collectors) if the water is flowing and it is flowing through the collectors/panels, then the water is being heated!
If you are saying the controller is set for solar operation and the sun is shining, and there is a "Demand" for heat or a "Call" for heat, and the Valve is NOT turning to allow the water to the panels, then you have a problem with either the Hayward/Goldline Controller or the Valve Actuator.
Good Luck
Nov 15, 2014 | Pool & Spa
Problem with jandy rs 4. Pool heat pump Is running. We didn't turn it on and the heat pump light on the control panel is not lit
Does your pool gave an attached spa?
IF it does have a spa, dies it also have a spa side remote?
If so the first step would be to unplug the spa side remote from the back of the board.
If the issue stops then you need a new spa side remote if it persists then it nah be be main circuit board or relay for the heat pump.
Nov 01, 2014 | Jandy AquaLink RS 4 P or S OneTouch Pool...
Rheem is showingcode "REM" and
should ask, Do you have automation or external remote?
if no..take off remote setting by holding the three buttons down until display changes.
If yes.. this is an auxiliary remote so heater control is deactivated, look to the aux. However, This will control heater on/off and temp control but only heat as high as heater set point allows. i.e. Heater set to 82 degrees will only allow remote up to 82 degrees no matter what you set so take off REM by holding three buttons on heater, turn all the way up to 104 then put back on REM
May 13, 2011 | Solar Rheem Gas Fired Pool & Spa Heater...
Rheem digital gas pool heater fan code
The Fan code would indicate a problem with the combustion air blower. The is a pressure switch to indicate there is sufficent combustion air, and if not then unit shuts down. Either the fan isn't running, or there is an obsturction in the fan or exhaust piping, preventing enough air flow.
cfh would be call for heat, which would be a normal display when water temp is below setpoint
See the link below for a manual. Once you open the page look on lower right side for documents, then install manual
http://www.rheem.com/product.aspx?id=2388EEB7-3DEC-4601-AE76-EC7A07F17630
Jul 04, 2010 | Solar Rheem Gas Fired Pool & Spa Heater...
Rheem model p-m266a-en-c digital gas pool heater runs, shuts down
CFH is call for heat not sure what spk is, but will find out and let you know.
Jul 05, 2009 | Solar Rheem Gas Fired Pool & Spa Heater...
Raypak pool heater piliot light on heat will not turn on
Make sure that gas control knob is set to ON (counterclockwise). Make sure that ON/OFF switch is ON. Check that temperature setting is high enough to call for heat. Make sure pool pump is running and water is flowing to unit.
If not above there is a diagnostic procedure on page 33 of manual at:
http://www.raypak.com/uploads/6000.52AG.pdf
May 24, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
No heat for the spa.
go to the heate and see if it tries to start and report back on any noises you hear or click or fans or is you smell gas
Jan 03, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Raypak Rheem M8350ti-E, 130 BTU Digital Heat Pump Logo
96 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Marvin
Marvin
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
