Question about Toymax Magnavox 37MF231D 37 in. LCD TV
Magnavox 37mf231d no sound or image - Toymax Magnavox 37MF231D 37 in. LCD TV
Posted by valentin gallard on
On my Magnavox 37mf231d tv when I turn it on, the backlights turn on for about 3-4 seconds, then turns off. There is no blinking green light, there is no green light at all. It seems like it is trying
Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
My magnavox 32 in will not stay on.
Sounds like main board fault. Contact any service technician to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Magnavox 37MF231d/37 LCD TV cycling thru colors
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
My 2 year old Magnavox 37MF231D/37 LCD TV just blew the picture screen. The audio comes through fine, but the screen is dead black with no menus, info, nothing. I tried various inputs, same result. I...
The problem can be in the backlight inverter board (hard to get to), or the main power supply module may not be working. Look at the power supply first since it is easy to get to, look for burnt parts, bad capacitors.
http://en.wikipedia.org/wiki/Capacitor_plague
Please
2answers
Magnavox 37MF231D 37" LCD TV "popped" now won't turn on at all!
Capacitors tend to pop when they fail. Phillips LCD TVs have lots of problems with capacitor failures in their power supplies. I've got my 37mf231d apart on my workbench as we speak. Mine makes a whistling sound which I believe is either a solder fault or a bad capacitor.
A new power supply board is about $150 for that TV. The gamble, of course, is if the power supply took out something else when it failed.
Magnavox 37MF231D
magnavox is the same unit as philips --- they are like dodge/chrysler--- made in the same factory--- try a company that services philips and they will be able to fix
Toymax Magnavox 37MF231D 37 in. LCD TV Logo
Top Toymax Televison & Video Experts
Ekse
Tom Chichester
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
