The oven paper (referred as ovenable paper some time), is made of wood pulp, coated with food grade silicone oil. It features in smoothness, high-heat resistance and non- stick, etc. The brightness of baking paper is over 88. The sizing value of baking paper is above 0.8.Its strength is more than 3000.
SOURCE: I have a 42" Vizio picture has an annoying thick red line
Ur backlight inverter video board is dying.
Need a new one.
SOURCE: I have a 47" Vizio
This problems the tv serveral vertical lines show up on the LCD screen panel by itself?Yes,the tv board that call the T-CON decodering board is dying.The T-CON decodering board it sit at the middle bottom of the LCD screen panel.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.If these vertical lines cause by an object or a person by hitting the LCD screen panel,tv is not repairable,because the LCD screen panel is dead not worth replacing because the LCD screen panel are 90% important to the tv and cost the same as a new tv.
SOURCE: vizio 32 inch thin black vertical line on left side of screen
it is very likly you have problem with the buffer boards, sometime help to unplug conector and reconect, also check the smd fuse located on one of the boards since there are 2 buffer E&F.
