Question about Kenmore 15218 Mechanical Sewing Machine
How do I lower my fee dogs on my kenmore+sensor+sew+70
Posted by 1shirleynewm on
3 Related Answers
Anonymous
  • 8 Answers
SOURCE: Dropping Feed dogs on kenmore model 19233
Remove extension table/accessory box by gentle pulling it away from machine. You are left with just the free arm. In the back of the free arm, lower left corner, you will fine the feed dog lever. Push the leaver to the right to lower the feed dog.Instructions for lowering and raising the feed dog are on page 48 of your owner's manual. Good luck!
Posted on Jan 01, 2008
SewTechWayne
SewTechWayne
  • 186 Answers
SOURCE: turns on does not work
It probably has a bad circuit board, I don't think they are available though.
Sorry!
Posted on Jan 30, 2009
Anonymous
SOURCE: serger
As long as this is a sewing machine and not a serger, I don't know about them. I only tinker on my own. Remove the bottom. There is a rod running along the length of the machine. it needs to be turned 180 degrees. You may need to retime the machine.
Posted on May 29, 2009
How to lower the feed dogs for free motion sewing on model # 16782
There are most likely some numbers missing from the model number you provided. Usually, there is a 3-digit beginning number, ie 115, 385, 401...
I am unable to find model information based on your number, but you can most likely get a user's manual through Sears or try searching the internet (Make Model manual), ie:
Kenmore Sewing Machine Manuals Instruction and Repair Manuals
Sewing machines generally have two ways to disable feed dogs. One way is a lever or knob on the machine itself that physically "drops" the feed dogs so they are below the needleplate. The feed dogs will continue to operate but since they are below the sewing surface, they will not have an effect on the fabric movement. The other way is an accessory that attaches to the needleplate which covers the feed dogs and creates a flat sewing surface.
Another item that is important for free motion quilting is a darning foot or free motion foot. These presser feet are physically shorter in height than a standard presser foot. This means the darning foot, when lowered, does not apply "pressure" to the fabric when it is lowered. It, instead, provides leeway between the presser foot and the fabric so there is room to manually maneuver the fabric while stitching.
You'll just need to CONFIRM that the presser foot shank is correct for your machine (low shank, high shank, slant shank).
There are probably a multitude of designs available for your machine, either Kenmore or generic brands. Once you've determined your machine's shank, it would be a personal decision as to the design you'd prefer, which could be metal or plastic, closed, open, or clear see-thru as well as various shapes, round, oval, etc. There are also some feet that are spring-loaded so they "hop" while you stitch, or feet that are solid.
These are examples of different darning/free motion presser feet.
Darning Foot Low Shank 4021
Nancy Notions Trusted by sewing enthusiasts for more than 3 decades
Amazon com Tinksky Sewing Machine Open Toe Metal Quilting Embroidery...
Free motion Darning Quilting Sewing Machine Presser Foot Fits All Low...
Nov 27, 2016 | Kenmore Sewing Machines
How to lower feed dog on kenmore sewing machine?
many machines have fixed position feed dogs .your might be one of them .
Nov 12, 2015 | Kenmore Sewing Machines
Kenmore sewing machine feed dog
Probably it is the spring loaded cam on the lower shaft not moving as it is bound up. The feed drop lever pushes it to the left to lower the feed dogs, but it has to spring back on its own after you move the lever back.
If you can remove the lower free arm cover you may be able to work it loose. Do not use 3 in 1 oil as it is gummy. Better to get Lilly white sewing machine oil.
Hope that helps!
Mar 12, 2014 | Sewing Machines
Can you drop the feed dogs on kenmore 385.1233280 or do you have to remove them to do free motion quilting?
Do you have your manual? Normally, there will be a lever next to your bobbin area to lower your feed dogs if you have a vertical bobbin. If, it is a horizontal bobbin it will usually have a cover to put over the feed dogs. If you are in doubt, take your machine and go to your local Sears sewing machine department, usually your salemen are very helpful and give great advice for free.
Jan 27, 2011 | Kenmore 19233 Computerized Sewing Machine
Clothes don't advance when sowing and the stitch is too tight
check the feed dog position,, feed dog has to be up to sew & move the fabric
check the top tension & bring the tension down to a lower number to see which setting is good for the fabric your sewing
Nov 30, 2010 | Kenmore 15212 Mechanical Sewing Machine
How to Drop Feed Dogs on Sewing Machine...
On many machines you tilt the machine back on its hinges to see the underside and there you will find a thumbscrew to lower the feed dogs...you also need to be sure that your machine is capable of having its feed dogs lowered...not all machines can do this!
Aug 25, 2009 | Janome Memory Craft 5700
Kenmore Sewing Machine Model #158.18032
You probably have a bind in the feed dog mechanism. If you can remove the covers and manually force them down you will see the hinge points that need to be oiled.
Unplug first!
Good luck.
Jan 20, 2009 | Sewing Machines
Feed Dogs Kenmore 158.19802
I think the feed dog lever needs to be positioned on the right.
Sep 15, 2008 | Sewing Machines
Dec 31, 2007 | Kenmore 19233 Computerized Sewing Machine
Kenmore 15218 Mechanical Sewing Machine Logo
75 people viewed this question
Top Kenmore Sewing Machines Experts
Irene Tulloch
Douglas Plant
Douglas Plant
tsalagi152
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
