After rebooting it works fine but eventually will go :blank" again. Everything else seems to work fine except the screen - no cursor or anything
SOURCE: display driver r300
You should uninstall & reinstall the Display Driver. If you can't do so, you should contact your Vendor or Service Center.
SOURCE: touchpad not working
If you are not computer savvy I do not recommend you trying to replace the touchpad, it usually involves completely disassembling the notebook.
Simpliest solution - plug in a usb mouse.
SOURCE: mortherboard,keyboard replacement on gateway m360
First I would ensure my video cable was firmly connected. Sometimes that connector does not seat all the way causing what you are seeing. That is the rectangular connector leading fro the cable on left side of the LCD to the motherboard. Normally there are several hardware components related to a white display. LCD, video cable, or motherboard all causes of white screen. Have you checked external video? What was the original issue before motherboard and keyboard replacement?
SOURCE: Audio/Video problems
Do you have any codec packs installed?
If so uninstall them and install these two.
http://sourceforge.net/projects/ffdshow
http://ac3filter.net/project/1/releases
Most popular media player
http://www.videolan.org/vlc/
SOURCE: my mic stopped working
double click on the speaker Icon on the task bar go to properties and make sure that the box for mic is checked
