Speed Queen AWS45NW Top Load Washer Logo
A
Anonymous Posted on Feb 22, 2013
How to i remove agitator on model AWN412SP111TW01
We have clothing stuck under agitator and need to remove so we can remove clothing
joel
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 17, 2015
joel
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
866
Points
I just removed it, tnx so much for ur help.
How do you remove the agitator on a speed queen model AWN412SP111TW01
https://www.pwslaundry.com/c-295313-commercial-speed-queen-awn412sp111tw01-top-load-washer-parts-for-repair-service.html?msclkid=e3bfa3c0ea10105c5fb3fe38f5e42190&utm_source=bing&utm_medium=cpc&utm_campaign=CPCS_DSA&utm_term=pwslaundry&utm_content=All%20Website
2answers
How do remove tne agiator in my top loading washer clothes stuck
a brand would really help me answer your question,most machine have a bolt down the centre of the agitator undo that to remove it,if the round disc type which is called a pulsator the is a plastic cap in the centre remove with a screw driver bolt is under that you may need a couple of screw drivers under it to pop it up
2answers
How can i get the agitator off a speed queen modle number AWN412SP111TW01
If its a standard top loader there should be a cap you can pry off on top of agitator. Screw or bolt is under cap.
1helpful
How to remove clothes stuck under agitator
the agitator should pull straight up, you may have to twist it back and forth as you pull upward. when you put it back on make sure its all the way down and in place, this may be the reason your clothes are getting stuck under it.
Item caught under agitator
The top of the washer pulls up. IT may be hard to do. This will expose the whole drum so that you can see around it. If you need to remove the agitator, there is a cap on the top of the center, take it off and you should see a nut and some lock washers, Remove the nut and lift the agitator out.
5helpful
3answers
Cloth stuck under agitator in washing machine.
there is a bolt under the fabric softner dispenser (if you have one) if not, its a plastic cap on the top of your agitator which pops off by hand or a butter knife.. then there is a bolt under there that holds the unit down..grap the bottom of your agitator and loosen the bolt and remove it...then lift up carefully on the whole thing..careful not to loose the seal and bolt to put the agitator back in place....good luck..
Clothes stuck under agitator pan
You'll need to remove the agitator.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Several pieces of clothing stuck under agitator.
you can remove the agitator. there are 3 steps to this. 1.take off the top plastic part of the agitator. 2 remove secondary plastic piece from inside of agitator 3. there will be a 7/16 bolt inside and will be deep so you will need a long extension to reach it. hold the fins of the agitator and remove the bolt with a ratchet. once the bolt is out you will be able to lift the agitator up.
6helpful
3answers
Clothing stuck on agitator with top loading washing machine
Dear Whitworth,
please rate this solution if it meets ur needs, else choose fixya...
The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Click here to order replacement parts.
please rate this solution if it meets ur needs, else choose fixya..Thank you.
Top Speed Washing Machines Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Speed Washing Machine Expert? Answer questions, earn points and help others
