Cars & Trucks Logo
Anonymous Posted on Feb 23, 2013
The car doesn't starts
Joe Jo
Level 1:
New Friend:
  • Contributor 11 Answers
  • Posted on Feb 23, 2013
Joe Jo
Contributor
Level 1:
New Friend:
Answers
11
Questions
0
Helped
1797
Points
31
Post a video with your whole dashboard when you insert the key fob and rotate it (if posible) trying to start the car. And keep your mouth shut please.
If the dashboard light up turn on the short beam and after 2-3 seconds the long beam.
2000 elantra white smoke during speed, doesn't start
White smoke normally indicates steam, did the car overheat ????...if it overheated check hoses for leaks,,,, loss of water etc
2004 Ford Taurus won't start?
get your battery checked
Truck has power but doesn't start. Starter doesn't click either
Have you checked the circuit between the key switch and the starter ?
There should be a starter relay and a neutral safety switch involved.
Mk4 gti vr6 has power but doesn't start, runs with pop start
Could be a number of things but may want to begin by checking wiring to starter, battery, or even the ignition switch. These components may not turn your engine light on.
2answers
1994 Toyota Camry doesn't start without shaking
sounds like it having trouble starting. when was the last tune up ,and are there any codes on.
1988 Trans Am will not start when ignition is turned all the way.
Take a test light to the small wire on the starter and have someone turn it to the start position. If the light lights up and the engine doesn't turn over, I would suspect the starter itself. If the test light doesn't light, try it in neutral and repeat test. If it still doesn't light up, it may be the PRNDL switch or the ignition switch itself.
Dodge caravan 1996 doesnt start
It is very hard to help you when you give no details. But if it doesn't do anything when you try to start it you probably need to charge battery or get new one. If it is trying to start and doesn't sound weak then you need to have someone look at it. It doesn't sound like you would want to do anything yourself but if its not the battery, it doesn't sound good. Good luck
4helpful
My 1993 corvette wont start
Car doesn't turn over,but ignition turns on? Doesn't happen all the time,it just happens.. If I let it sit for a while it all of sudden turns over and starts. Happened twice this year..
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
