I am having problems getting these wireless rear speakers and receiver to sync to the stereo system
Posted by eddie vidal on
Harry Husted
    New Friend:
  • 37 Answers
Is your stereo system set up for wireless communication? If it is, you may have to go into the user manual for the stereo, to find the setting for it. The wireless setting may be set to off by default.
Posted on Feb 23, 2013
4 Related Answers
Anonymous
  • 3130 Answers
SOURCE: Problem adding wsp155 wireless speakers.
You must check with the instalation gude for the wireless speaker to see if the connection to the reciver is a high impedence or low impedence... If its like most wireless set-ups its going to be a high impedence output from the reciver to the transmitter part of the speakers. That would be from the RCA jacks in the back of the reciver maked line out or tape out. If you want to use them for a specific speaker output , some recivers have an output jack that would be labeled center sperker out but would be an RCA type jack ect ect. If your reciver dosent have that you can in a higher end audio store get an adaptor to convert the speaker output to a high impedence, But I dont recomend that as some of the adaptors do cause excessive strain on the output section of the amp or reciver.. If you buy a good one though you should be fine.. You get what you pay for.. Good Luck
Posted on Aug 06, 2006
ABRsvcs
  • 4234 Answers
SOURCE: Stereo speaker problem
The speaker is bad. The receiver detects a shorted condition and shuts off to prevent the amp section from damage. Replace the speaker or the wires. Something is shorted.
Dan
Posted on Apr 02, 2008
Anonymous
  • 50 Answers
SOURCE: Yamaha HTR-5660 receiver but no surround sound
have you tried putting it in a different program mode?
Posted on Jul 05, 2009
fkuk
fkuk
  • 311 Answers
SOURCE: I have an Acoustimass 10 system with SL 2 Wireless
when you play real DVDs?
im assuming you do
DVD quality is higher than standard TV signals and also TV signals are subject to noise from the envionment
as for DVD there is every little chance for noise because its from DVD player to speakers.
what you could try is swapping the cables that carry sound from the DVD palyer to the system with the ones that carry sound from the TV to the system
if you can
and see if that helps but i doubt that it will help
all i can say is you have to live with the noise or get a HD reciver or something along those lines
also i just read that the back speakers are wireless temporarily move the wireless speakers towards the transmitter and see if the noise stops
or if you can hard wire them temporarily and see if it helps
Posted on May 12, 2010
Where can i find a radio diagram for a 24 pin 05 cobalt with pioneer speaker system
Car Radio Battery Constant 12v+ Wire: Red/White .
Car Radio Ground Wire: Black/White
Car Stereo Antenna Trigger: Yellow
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: Factory amplifier is located behind the driver side of the dash (near the firewall).
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Dark Green
Right Front Speaker Positive Wire (+): Light Green/White
Right Front Speaker Negative Wire (-): Light Green
Left Rear Speaker Positive Wire (+): Brown/White
Left Rear Speaker Negative Wire (-): Brown
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Tan
Nov 03, 2016 | Pioneer Car Audio & Video
HTS9800W/12 and rear speakers
click this site:
http://www.avforums.com/forums/archive/index.php/t-378942.html
Jul 10, 2008 | Philips Cineos HTS9800W System
My two wireless speakers are not working. the wireless receiver flashes blue 10 times then turns red. It was working fine and now is not
I am having the same problem with my LGHB905TAW. Called local support without any feedback... I think this is the bug in design phase.. Search around the internet but without any positive result...
Sep 27, 2011 | LG LHB975 Theater System
I don't know how to connect the speakers to my insignia receiver.
Well, this is a two channel (stereo) receiver. If you have two speakers, look to rear of the unit and connect right speaker to the right output terminal and vice versa with left speaker. If you have four speakers, there are an option if the receiver has systems A and B of speakers set. Do the same with B system and listen to all four speakers using switch at the A+B position. Good
Jul 21, 2010 | Insignia 200W Stereo Receiver
How to make my rear speakers wireless wat do i need
If you are considering using bluetooth for this, you will need a transmitter and receiver for each speaker pair. Each speaker pair will need to be driven by an amplifyer which interprets the bluetooth signal and drives the speakers. So for a 5.1 sysem, you will require 3 amps, 3 transmitters and 3 receivers. Also the power packs for charging the transmitters & receivers. Jabra make a very nice transmitter which I use, Its an AS 120S;. The 'S' is for stereo. For receivers I use a simple cheap unit I got off eBay. Item number 320519321206, which is a better unit than the Jabra. You have to have all signal through bluetooth (or none) because of the few milliseconds delay this technology produces.
Apr 18, 2010 | Samsung Audio Players & Recorders
Instructions on how to hook up outdoor speakers to computer
Get a set of wireless speakers (such as Advent AW-820 900 MHz Wireless Stereo Speaker System).  Connect the transmitter to the earphone jack of your computer.
May 20, 2009 | KLH Audio Players & Recorders
Wireless speakers
You should have two pieces for your wireless rear speakers setup. A. a wireless card inserted behind the all in one receiver. B. the receiving box that will connect to the 2 rear speakers.Also,you should not have any obstacles to block off the line of site for the rear speaker receiving box to the wireless card.
Best way to test it is too simply leave the rear speakers connected to the rear speakers receiving box on the floor near the a/v receiver with dvd player built in.Play a dvd and see if you have sound coming out from the rear.
solutiondoct
Nov 01, 2008 | Panasonic Home Theater System System
Rear Wirelss speaker do not work
With the main unit turned off, press and hold [REMAIN] on the home theater's remote for 4 seconds. (The REMAIN button is directly under the 7 button). Once held down for 4 seconds, the Volume Indicator on the main unit will turn on for 1 second. Release the [REMAIN].
Press the [RESET] on the back of the Wireless Receiver 2-3 times. The Standby/On LED on the front of the Wireless Receiver will blink 3 times
Turn on the main unit. The Link LED on the wireless receiver will light up if process is done correctly. The front of the main unit will no longer say REAR CHK and the rear speakers should now function correctly.
Feb 24, 2008 | Samsung HT-WX70 Theater System
No sound in wireless speakers and subwoofer.
I had the same problem and tried it both ways. The sound did come from the rear but was very soft. I used the microphone that came with the receiver to optimize the sound and that also helped. But what I really noticed was that certain movies make use of the rear speakers more then others.
Dec 05, 2007 | Panasonic SC-PT1050 System
89 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
