Hy I have monitor samsung 226BW and it starts flickering. It was only worse and then it doesn't want to start. I opened LCD and replaced capacititors which were blown up. So that problem is solved, but lcd won't turn on. Its just like the power button don't work. When i plug monitor in electricity the backlight turned on for 5 sec and then it turned of and that is it. I am runing out of an ideas what could be wrong. Buttons works normaly, power board also. Its got to be something on logic board, but what. Thank you for answer. :)
SOURCE: Samsung 226BW 22" LCD wont turn on and flickers a blue light
Hello cstafford35,
Your monitor has a very common problem. The internal power supply has blown a part called a capacitor. If you are comfortable working with electronics and with soldering I can talk you thru the diag/repair. If you are not ready to tackle that we also offer a repair service, about $30 plus shipping for your model. Let me know if you want to try fixing it yourself and we can go from there. The repair will require opening the monitor case and replacing from 2 - 5 parts. You can call me at 318-447-9040 if you have questions.
Buddy
Corporate Computer
SOURCE: samsung syncmaster 226BW no backlight
Look for any bulging capacitors, instead of a flat top they will look "pregnant".
If you see any of those then replace them with capacitors of the same UF rating and the voltage needs to be either the same or higher.
If you dont see any bulging capacitors or burnt parts, then its got be the LCD at that point thats not staying on and the cost to replace the LCD is as much if not more then to just get another monitor.
SOURCE: Samsung LCD 226BW is flickering
Yes,
The power inverter is the problem but you can repair it yourself. Check out our web site at: www.ccl-la.com We have a step by step repair guide for this model, its the same as the 214T. The repair requires replacing 5 small parts that will need to be soldered. If you don't want to do the repair yourself we do offer a repair service for $30 plus shipping. If you have any questions or need service contact us at [email protected]
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
SOURCE: Samsung LCD monitor (SyncMaster 710v) displaying white stripe.
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
SOURCE: Recently, the characters on my
Yes, myou may have failing DC filter caps, just like the rest of the monitors as shown in my albums here:
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Testimonial: "Thanks for confirming my suspicion"
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Please post back what you find.
