E1-F5 Code
SOURCE: Error code E1 -F5- Broil element comes on and wont shut off
I just did the self clean option and when it was done I received the error code E1 -F5- and it does have to do with the door latch. After turning off the power to the stove I was able to open the door and wiggled the latch and that solved the problem.......
Posted on Oct 24, 2007
SOURCE: f5 code on a kenmore range
Hi mrscottd,
The f5 indicates a loss of the relay drive circuit. To correct you can turn the power off to the range at the breaker box and wait about 10 minutes, then turn back on. This will reset the board. If the error returns you will need to replace the electronic range control (ERC). The part number for the control is # 338692 price $338.49 at Sears or My price $299.99 delivered. Good luck to you and please dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
Posted on Oct 30, 2008
SOURCE: KitchenAid KESS907 Electric Range E1 F1 Error Code
F1 E1, replace Electronic Range Control.
In other words, the controller board has failed.
Posted on Jan 29, 2009
SOURCE: We used the self cleaning option on our Kenmore
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
SOURCE: E1 F5 Error Code Oven will not work
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(*&YH
Posted on Oct 01, 2010
Mar 30, 2011 | Kenmore 92022 / 92024 / 92025 / 92029...
Sep 25, 2010 | Kenmore 9535 Electric Range
Jul 22, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
Jun 27, 2010 | Kenmore 95022 / 95024 / 95029 Electric...
Jun 11, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
Dec 09, 2009 | Kitchen Ranges
Apr 01, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Dec 21, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Sep 06, 2007 | Kenmore 95822 / 95824 / 95829 Electric...
53 people viewed this question
