Question about Exercise & Fitness
I have a PROMASTER PROSELECT treadmill it stop, and error came up #30
Posted by Micchael Rutgliano on
ernesto cuadra
    Top Expert:
  • 12,223 Answers
Description
Errors 30 through 33 all indicate the loss of communications or erratic communications between
the microprocessors in the upper PCA and the lower PCA. The trouble shooting procedures for
all of the are essentially the same. Error 30 is defined as upper PCA not receiving from lower
PCA. Error 31 is defined as faulty data received from lower PCA. Error 32 is defined as lower
PCA not receiving from upper PCA. Error 33 is defined as faulty data received from upper PCA
Possible Causes
1. An upper PCA to lower PCA interconnect cable is bad.
2. The interconnect cable at the upper PCA was mistakenly plugged into the CSAFE connector.
3. A 5.17 EFX equipped with version 1.01 upper and lower software.
4. A 5.17 with mismatched upper and lower software.
5. A defective lower PCA.
6. A defective upper PCA.
Possible Remedies
1. Substitute a know good interconnect cable between the upper and lower PCAs to determine
if the interconnect cable is defective.
2. Remove the interconnect cable from the CSAFE connector and insert it in the correct upper
PCA connector.
3. Replace the 5.17 upper and lower software with the most current software versions.
4. If only one of the upper or lower software is version 1.01, replace the version 1.01 software
with the most current version of software.
5. Substitute a known good lower PCA to determine if the lower PCA is defective.
6. Substitute a known good upper PCA determine if the upper PCAs defective.
PCA =printed circuit assembly. test it and fix it.
God bless you
I have a PROMASTER PROSELECT treadmill  it stop, a - 2_22_2013_6_07_30_pm.gif
Posted on Feb 22, 2013
2 Related Answers
lkderosier
SOURCE: richelle07
was able to locate error codes from manufacturer.
Posted on Sep 10, 2009
intower18
Eury Satorre
  • 957 Answers
SOURCE: Star Trac 2 treadmill. Power supply ok.
This link below is very helpful, please visit this link below for you to get a solution to the issue:
http://support.startrac.com/index.cfm?fuseaction=tech_docs.DocList&shty=ALL
Posted on Jul 31, 2011
I just got a speed error message on my display of a Smooth Fitness 735 The belt stops with me on it about 30 seconds after start.
first of all you have to check the speed sensor of the treadmill. If there is dust accumulated or the miss alignment of speed sensor can lead to mentioned problem .
Check the video to more
Eletric treadmill Speed Sensor Adjustment
www.electro-medical.blogspot.com
Sep 20, 2015 | Exercise & Fitness
How to adjust tension belt on pacemaster proselect treadmill
Tread Belt Tension Adjustment - Aerobics ProSelect ...
www.manualslib.com > ... > Treadmill > ProSelect > Owner's manual
Aerobics ProSelect Manual Online: Tread Belt Tension Adjustment. Step One:Locate ... Treadmill Aerobics PaceMaster Gold Elite Owner's Manual. Treadmill (38 ...
Aug 26, 2015 | Exercise & Fitness
Error code e11 I have kettler track motion , treadmill stopped working what do I do
Reset the treadmills, disconnect the power for 30 seg. or reset the small switch to the side of power button. and try again.
However you must RUN the software calibration for e11. and fix it
go to the HOOD cover motor, and follow the steps .
God bless you
Sep 30, 2013 | Exercise & Fitness
My treadmill no longer asks me for my weight, and I'd like to reset it.
go to reset. Turn off the power and reset the button too. Try again.
After that RUN the software calibration for easy diagnose, troubleshooting and fix it.
Happy New Year. God bless you
Jan 01, 2013 | PaceMaster ProSelect Treadmill Incline...
Treadmill no longer asks me for my weight, and I want to reset it.
try to turn off the machine. and reset the button and try again.
Happy New year. God bless you
PaceMaster ProSelect Error Code 31
mean defective lower PCA or upper PCA, try to tight any plug or connector or ribbon cable, However RUN the software calibration for easy troubleshooting , and fix it.
Go under the hood motor, and follow the step how to enter in the s. calibration.,see the block diagram attached.
God bless you
Nov 12, 2012 | Exercise & Fitness
Proselect pace master treadmill incline does not work
Dear Sir:
1) You must test the Main motor board, RUN the software calibration for easy diagnose and troubleshooting.
2) The elevation motor has a Potentiomente adjust. 3) The gear from elevation motor can be LUBE. However RUN the s. calibration.
3) Another machine has relais for down and up, you must clean the relais contact, if the board has relais.
sincerely. God bless you
Apr 23, 2012 | Exercise & Fitness
Treadmill works for 30 seconds and then stops saying E1
Your problem might be that a magnet has fallen off. Here's an illustrated guide that should make fixing easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Oct 05, 2010 | Startrac Fitness Products Star Trac 3900...
Exercise & Fitness Logo
266 people viewed this question
Top Exercise & Fitness Experts
Tom Chichester
ray gallant
Marvin
Marvin
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
