My xbox 360 fell and broke the upper panel but my xbox have been working that time after one day i changed my xbox panel know my remote r not detecetin to xbox pls help
SOURCE: Help Microsoft Xbox 360 Wireless Receiver For Windows, help help
I bought this system recently, and it had the same problem from the beginning.
I
opened it, and found that the problem was the F1 Fuse that is cutting
the current. You have to open it and bypass (soldering) the two legs of
the F1 Fuse.
This is how to open it: http://img22.imageshack.us/img22/6896/openingoi6.jpg
and this is the circuit: http://img14.imageshack.us/img14/231/receivereb4.jpg
Hope this will help ;P
SOURCE: My Xbox 360 wireless controller battery pack broke!
Well as you probably know all there is to a rechargable battery pack from xbox is 2 generic batteries that connect to the plate that connects to your controller. I recently took mine apart to try and fix it because it was not working at all. If you still have the original battery case that takes the AA batteries i would go out and buy a rechargable battery base and charge the cheap *** batteries that xbox uses in their packs. Then use the batteries that came out of the pack and put them in the original harness. Or you could just use the ones you buy.
SOURCE: xbox 360 wireless controller is not detect by xbox
You need to replace the RF Module. It is the little board behind the power button on your 360.
SOURCE: I can't get my remote from my old xbox 360 to work with my new 1
If wireless, then push the sync button on the front of the console and on the controller.They are located on the top and in between the left and right bumbers of the controller.
SOURCE: my xbox 360 controllers will
I'm sure you have tried most of these steps but I'm going to list them any way. So we have a complete picture of the trouble shooting process.
1. Sync system first (By pressing the sync button on the system)
2. Right after you hit the sync button on the system, hit the button on the controller
Try replacing the battery's and or rechargeable battery for the controller. Repeat the sync process above.
Try another controller with your xbox or try your controller with a different xbox. Repeat sync process above of course.
If another controller works with your system than that would indicate that there is an issues with your xbox controller.
If your controller works with another xbox and no other controllers work with your xbox than there is a issue with your console.
For issues related to the xbox I would suggest contact xbox directly by calling 1800 my xbox.
If possible please rate the solution I have posted.
