Where OH Where can you buy parts for a JVC MX-C33 compact componet system. I have gone to JVC and they are so very limited!!
My CD changer mechanism assembly doesn't work, it hums but doesn't open, I have no repair shops around where I live, so it is either replace unit or try to fix myself. yet with no parts how do you fix something that is broken, bewildered I am.
Posted by Frank Champ on
Grubhead
  • Audio Player... Master
  • 5,700 Answers
Most of these CD drawers are driven by a small belt that's either broken or come off. All you need do is find the belt, measure the diameter in MM and then put "??MM drive belt" into Google. You don't have to be precise with the measurement. So if it's a 45MM a 40 or 50MM will do.
Posted on Feb 23, 2013
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: Denon UD-M50 cd changer. Need help extracting drawer for home repair!
Hi KathyKate
If you are still having the same problem with your denon UD-M50 I might be able to help. I have fixed a number of them in the past and have the necessary maintenance manual and knowledge of a company that can supply spare parts. Disassembly looks very complex, especially when the problem is with the carousel but once you have an understanding of the mechanism it's not that difficult. Care should be taken when manually removing and reloading the disc trays as damage can result to the 'Teeth' alongside each. Spare trays are available. All my repairs involved the removal of the carousel mechanism in order to align the trays. I can copy the relevant sections of the manual dealing with the re-alignment which is critical but again if followed exactly you should have no trouble. If you respond with an Email address, I will be only too pleased to forward you the schematics etc.
Regards Ibbotsnm
Posted on Dec 15, 2007
Anonymous
SOURCE: rca compact stereo rs2657 cd door won't open
Mine was doing the same thing so I unplugged it and took the left side panel off to see what was wrong with it. I did this by removing the 2 screws on the left and the 3 on the back left side also.There was a cd stuck in it. It took some fenangling but I got it out and it works fine now. I know, I know. We as lay people are not supposed to do these things but it was out of warranty and would have cost me as much to have it repaired as to buy a new one. Good luck!
Posted on Dec 26, 2007
sanjin
sanjin becirbegovic
  • 56 Answers
SOURCE: broken cd player
The motor is last thing to gone before you go to service check the rubber belt which connect the motor to the door gears.Your set is 20 years old and this should be the problem and easy to fix
Posted on Feb 19, 2008
Anonymous
SOURCE: How to disable demo mode on JVC MX-c220
Make sure the unit is on. Press the FM Mode /Mute -Demo button (right next to the power) press it untill you get to either mono or auto (-for stereo). That will take the unit out of the demo mode. next turn the music jog dial (located just above the preset buttons) untill you get to which ever setting you choose. Hope that helps. ( I can't find the manual on line either- not even from JVC! )
Posted on Jun 10, 2009
Anonymous
  • 8 Answers
SOURCE: how to unlock protected mode on a jvc 5 disc cd changer?
cheack the speaker wireing.if thats not the pro i sugg the repair shop your unit could have over heated.
Posted on Mar 01, 2010
JVC MX-GT88 sound system showing protected them shut off why
Chances are that something is blown in the power output stages and units shuts down to protect against further damage.
Repair or replace, which ever is cheaper!
Dec 08, 2015 | JVC MX-GT88 CD Shelf System
Jvc stereo model mx-kc4 cd tray won't open make loud noise
sounds like theres something keeping it jammed in might be one of those pull hard and hope jobs :) good luck
Mar 24, 2012 | JVC MXKC4 360-Watt Compact Component Audio...
How to line up trays etc in the changer mechanism
There is a lot of timing that must be checked before the changer trays are assembled back.
You will need to check the timings setttings of the tray which must be set according to limit switch and the mode switch
Jun 16, 2011 | JVC MXKB30 300W 3-Disc CD Shelf System...
Is the JVC CH -X400 compatible with the KS-FX222E?
Hello
The devices you specified here; JVC-CH-X400 and JVC KS-FX222E are non-compactable.
May 26, 2011 | JVC CH-X400 12-Disc CD Changer
I just purchased a used JVC MX-C33 stereo and the FM radio is ot working. Do I need to have apecial antenna or other gadget to get the radio to work? DO not have the manual. Thanks
I have a used JVC MX-C33 and put the cartridge in with only one cd and only one tray in the cartridge. Now it wont eject nor will the single slot open. Any suggestions on how to open it? Thanks, Monte
Apr 28, 2010 | Audio Players & Recorders
JVC MX-C33 Tape Drive Problem
there are small rubber belts that drive the tape spindle that makes the tape play! Over time these stretch and become loose and make the tapes play slowly and even shut down (replace belts and it should be fine) these belts are located in back of tape spindel and are about two inches long!
Please rate my answer and keep this site FREE!
Dec 31, 2008 | JVC MX-J30 CD Shelf System
Jvc compact componet system 5 disc dvd/cc player
check if you have sound on the tuner if you do it`s the mpeg board under the cd mech thats faulty
craig:)
Oct 19, 2007 | JVC 5 Disc Progressive Scan DVD/CD Shelf...
214 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
