Just received two days ago, plugged in tonight, light will not come on?
SOURCE: Avanti Beverage cooler gets too cold
Hi, sounds to me as though your temperature control is faulty, and the unit is running all the time. This control will have to be replaced. This is something you can do if you take your time and draw a wiring diagram in case you forget. It will have a long coiled up wire with a bulb on the end of it mounted in the evaporator section in the refrigerator section. This all comes out together. This is the only thing that would cause this problem. Get all of the numbers, model, serial, and part numbers when you go to the appliance parts house to get one. You should have no problems in doing this. Please keep me posted as I am sure this unit is worth changing out the stat.
Sincerely,
Shastalaker7
SOURCE: I have a Beverage Air
Hi Your breaker is tripping because the circuit is overloaded and gets hot enough to cause a disturbance in the circuit. This can, indeed, be very dangerous. Unless there is a dedicated circuit of 20 amps to the refrigerator this will continue to happen When your refrigerator goes into defrost and other things like lights fans air conditioners are on the same circuit it will have no choice to not trip the breaker. You need a 20 AMP circuit or this will possibly damage the compressor or weaken the breaker because it has tripped so many times. Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
SOURCE: beverage cooler making noise
There are small fans that they incorporate in those. If you can get to it put a drop of 3 in 1 oil on each end of the motor.Some of those little bottles of oil have a telescoping straw like piece that extends out a couple inches.
The average wine cooler won't offer temperature below 46
Fahrenheit. Due to this fact you can store most of the light beverages in it
but it is not meant to store this kind of drink. I suggest you to purchase a
mini refrigerator in order to store your other drinks.
