Pentax ZX-30 35mm SLR Camera Logo
Question about Pentax ZX-30 35mm SLR Camera
This camera has the option to print date and time on the photo?
1 Related Answer
Glyn Kendall
  • 146 Answers
SOURCE: Can the date be printed on the photos?
Hi, I found this on the Pentax website.
It looks like you cannot print the date directly from the camera but you can do it using other options.
q.gif How can I print the date on my pictures? a.gif You can print the date on your picture using a DPOF compatible printer or at a printing service or by using the provided software ACDSee for PENTAX.
Posted on Feb 01, 2010
Cannot get date to print on .jpeg images when downloaded
The date and time (and a lot more) are stored with every photo in its EXIF metadata. If you want the date printed on your photos then please refer to the documentation for whatever program you're using to print. Depending on the program and printer you may have the option of printing the date on the image, in the margins, or on the back.
I wuld like the date to appear on my printed photos. Is there a setting I can change on my camera to get this to happen?
The stylus Does Not have the option to burn the Date and Time data onto the photos directly.
However if you are plugging your camera directly into the printer the camera gives you an option to add the date.
Follow this link to the cameras manual
http://www.olympusamerica.com/files/oima_cckb/Stylus_1020_Mju_1020_Stylus_1010_Mju_1010_Instruction_Manual_EN.pdf
Pages 40 - 44 explain in great detail how to print with the date.
1helpful
3answers
How do i remove the time and date at bottom right corner of picture.
Manual can be downloaded free from here ....
http://safemanuals.com/annexe_POWERSHOT%2020A550%2020CAMERA%2020USER%2020GUIDE%2020ADVANCED%2020_CANON_POWERSHOT%20A550-_E.htm
Basically the date stamp can be turned on / off as an option on the RECORD menu. Page 33 of the manual explains it (with pictures).
Note that if the option is turned on, it states that the date / time is permanently embedded in the picture.
Hope this helps
10helpful
Show/print date stamp on my photos
In order to imprint the date stamp on photos, the photo size (L, M1, M2, M3, S, Postcard) must be set to Postcard, and in the recording menu the "Date Stamp" option must be set to Date or Date & Time.
1helpful
2answers
Need some1 2 explaint to me how I get the d&t printed on the photo for a canon powershot 1S camera please
you can Print the date and time to the picture when you take the print of it. It does not embed the date and time data into the image itself.
From the manual please read this
" Setting the date and time settings does not cause the date/time stamp to appear on images"
To print with date
This option will be available only for printing on card size paper
In the print order screen, select [Style] and press the SET button
You will get 3 options to set
1) Image
a) Standard b) multiple
2) Borders
a) Borderless b) Bordered
3) Date
a) On ( Adds the date to the print )
b) Off ( Prints without the date )
Select Date option as On and the date will be printed on the picture.
still you are having any doubts, please refer to user manual and Direct Print User Guide
which i am giving as links here.
user manual
Direct print user guide
Hope this helps you
Thank you
1helpful
Date & Time Stamp
The date is printed on the photos using the "pict bridge" software. The date printing option is set on the computer, not the camera. If the printer has it disabled or it is a printer that doesn't support it, you won't get the date.
3helpful
Cant get date to print on phots
The photos taken by EOS cameras don't have the date & time overlay. To print your photos with date/time stamp, use Zoombrowser EX software that came with your camera. When you select photos for print, you'll get the option of printing the date/time (and even the choice of font's colour) on the photos.
Time and date on sony cyber camera
John,
Hook camera to digital photo printer directly with usb port and print photos through PicBridge option available in camera then printer will show you an option to have date and time print on photos.
Need further info, let me know.
1helpful
Print the date on the image/photo
It is not possible to embed the date/time stamp as part of the image itself with the XT. The date/time information is stored as part of the exif information stored in the image at the time of shooting.
However, you do have a couple options for printing images with the date/time stamped onto the image:
If you use the direct print capabilities of the camera when connected to a compatible printer (PictBridge, CP, or DirectPrint are all supported), you are able to enable an option that will print the image with the date/stamp printed on the image. There are also software packages that you can use that will do the same when printing from the computer.
And finally, it is possible, with some photo finishers, to request that they imprint the shooting date/time on the image. This will vary from photo finisher to photo finisher, and the will be some who can't, or won't, do this.
Cant print date on Image
you can only print dates on photos when your camera is set on post "card" (compact) mode...try it
Top Pentax Photography Experts
Steve
Are you a Pentax Photography Expert? Answer questions, earn points and help others
