Radio Communications Logo
Question about Radio Communications
Icandy bluetooth headphones wont turn on but it will charge help??
My icandy bluetooth headphones used to be working but they wont any more i plugged them in and a red light comes on but wen i try connect them to my laptop or phone they wont work. Help??
Anas Khan
Sir i have a icandy freedom 180 headphones but i dont know how to charge them. It does not have any charging except for Aux port thanks. Kindly explain it with detail how to charge them thank you
Posted on Jan 09, 2019
  • Anas Khan
    Anas Khan Jan 09, 2019
5 Related Answers
karlheinz
SOURCE: Setup Bluetooth Wireless headphones
Each brand has it's own peculiarities and you did not specify the brand. I would suggest turning off the headphones, resetting the transmitter (turn off and on again for separate devices) and then pressing and holding the 'on' switch for 15 seconds or so. You may see (in some models) a light start to blink blue then red and back. This should indicate that the receiver (headphone) is trying to find a transmitter to pair with. Hope this helps.
Posted on Dec 14, 2007
Anonymous
SOURCE: Headphones has red light
Hello, I believe I just figured out the solution to this problem. I was experiencing the same thing, and as I was just showing my friend the problem I noticed that the green light came on after I turned on the music on my computer.
So, after removing the headphones from the base, the green light will come on only if there is sound playing from the computer (It takes a few seconds to turn on). It seems like they should have mentioned this somewhere in the manual...
Posted on Dec 31, 2007
Anonymous
  • 7 Answers
SOURCE: Won't charge up...
I had the same issue. So what I did was get a small screwdriver, opened the A210 case removed the battery. You will notice orange tape (remove it) then attached to the battery is a small board (the defective part) . Cut away the board, then you will need to solder the wires back to the thin metal film leads. And voila it will now charge, make sure to never let it charge for more than 2 hours. Do this at your own risk. Of course this will void the warranty.
Posted on Feb 04, 2008
Anonymous
SOURCE: Windows Vista wont connect to these headphones
Try going to control panel->sounds->make the hands free audio the default.
Posted on Aug 09, 2008
Anonymous
  • 5 Answers
SOURCE: why does insignia ns-bthdp have a solid blue light?
I had this problem but the red light was on constantly with no response to anything I did. I plugged this into my power adapter and pressed the + and - buttongs at the same time and it reset and started working properly.
Posted on Dec 14, 2008
My bluetooth headphone LG HBS 800 is not taking charge.What to do ??
have you replaced battery?
1. charger is not working
2. battery is bad.
2answers
I have not use the bluetooth for long time after first charge. now i'm trying to charge it, but i does not work. how can i fix it?
If the bluetooth you are referring to is a bluetooth earbud, the batteries may be dead. You may need to buy a new earbud.
My JBL E50BT Headphones bluetooth wont turn on. when i press the bluetooth button nothing happens and no light shows (normally light shows and you hear a beep) please help.
I would start by charging the headphones overnight. Try to use them in the morning. If this does not resolve the problem, either the charger or the headphones are bad. You can contact JBL and see if your set is still under warranty. You should still be able to use them with a wire if everything else fails. It might not look as cool, but at least you can still listen to them. My JBL Account Login
10helpful
2answers
Insignia Bluetooh Headphone won't turn on. but can charge
put the charger in your headphones and hold both volume buttons
you should see a slight flash of blue light then press the multifunction to turn it on
2helpful
2answers
My Insignia NS-BTHDP headphones don't have a red charge light anymore. The first charge out of the pack had the red light on. But now the red light doesn't come on anymore. I wonder if it is really...
The LED may have just gone bad. Keep using it untill the battery dies, then try charging it and use it again. If it works as it should it means the LED died and there is nothing to worry about, if not you may need to replace the battery.
31helpful
4answers
Well i fix it putting on power and pressing both volume buttons for 15 seconds. Then he turned on with no problems
6helpful
2answers
Red light wont go off headset wont turn on
SImply connect the headphones to a power source. Then press up and down volume buttons at the same time. It will reset the headphones.
2answers
Headphones wont turn on
battery is toast get a new one anything electronic if u do not upkeep the charging it will die qwik
25helpful
6answers
Won't charge or turn on.
I wrote to Insignia and they recommended the following procedure, which worked for me:
1- Plug the charger into a power outlet
2- Press the Volume Up and Volume Down buttons at the same time for resetting the device.
My earphones are working well now.
Regards,
Celso
Top Radio Communications Experts
Marvin
Marvin
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
