Question about Whirlpool 24 in. Portable Dishwasher Dishwasher
Pump on dishwasher not pumping
Pump is not pumping out
Posted by ken wright on
Caleb Wright
    New Friend:
  • 4 Answers
Replace the pump. It's gone out
Posted on Feb 22, 2013
My dishwasher will not empty
In many cases the dishwasher will stop draining or draining fully due to a clogged drainage hoses or due to an object caught in the draining pump. There are some cases when the draining pump is faulty and needs to be replaced. We have assembled the top issues to check for a dishwasher that does not drain.
Drain Pump: The drain pump pushes water through the drain hose. If the drain pump motor is malfunctioning the dishwasher will not drain. Drain pumps can be checked with a multimeter. If there is no continuity then it must be replaced with a new part.
I got this info from:
https://www.electrafixbc.ca/appliances/dishwasher.html
Check it out for more help with your dishwasher issue.
Nov 02, 2019 • Dishwashers
2helpful
Dishwasher not spraying/pumping water in wash cycle
If your dishwasher is filling, draining and the heating element is working then the wash pump motor has probably failed.
You have not provided the manufacturer and model number, so I have no way of knowing if your dishwasher has a separate drain and wash pump motor.
May 03, 2009 • Dishwashers
1helpful
Almost new dishwasher. Lights come on but pump doesn't start
You have some debris in the little pump that pumps the water out of the dishwasher. To get at the pump you will remove the lower front panel and follow the drain line down toward the floor. there u will see that the drain line is connected to a small pump. disconnect the drain line and remvove the two screws that hold the pump to the frame. look in the pump and you will see your problem debris [often a chunk of glass or bone] Remove it and put everything back to gether and you will be back in business.
My dishwasher does not completely drain after a wash. what do i do?
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit
  2. Check the check valve and drain hose for debris.
  3. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  4. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  5. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  6. If you have recently installed a new garbage disposal, check knock out plug at connection.
  7. Check pump impeller for damage.
  8. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off
Pump makes a grinding noise
Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
Good luck...
Dishwasherwont wash
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Check if motor spins. In case it spins, the problem is with the pump ,in case it doesn't spin it could be a motor problem or a motor and pump problem. Good luck
Washing
Whirlpool 24 in. Portable Dishwasher Dishwasher Logo
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Ekse
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
