How to use the dish washing machine 'Constructa'
Posted by tema_tumanov on
sweengsxr
    New Friend:
  • 3 Answers
Open the door and put all the way to ur left inside the dishwasher and close the door start your washer
Posted on Feb 21, 2013
3 Related Answers
Anonymous
SOURCE: instruction manual
Option B is the standard option for whites and colors and is approx 125 mins long. Option A adds a 25 min soak. Option C/D is the short cycle at 70 mins. I haven't figured out how to program an extra rinse yet.
Posted on May 04, 2009
Anonymous
  • 6277 Answers
SOURCE: Please, be so kind to
Sorry but this forum does not supply manuals or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home, with often huge amounts of experience of addressing peoples problems with their machines;-0)
I suspect that even if you contacted the manufacturer (on-line) it might not provide you with one- they are usually reserved for the service engineers rather than we public but good luck anyway!
John C
Posted on Feb 18, 2011
Anonymous
  • 6277 Answers
SOURCE: i have constructa cr 5001
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct.
Also here is a direct site URL- http://steprightupmanuals.com/washing-machine-service-manuals/
If this has assisted you please consider a 4 thumbs-up for the rating.
Thanks and good luck!
John C.
Posted on Apr 14, 2011
Constructa e2
Unplug it for about 1/2 hour and try it again.
Dishes come out feeling gritty. Using Finish doesn't help
If you open the door immediately after the dishes are washed, and before the "dry" cycle, is the water hot enough to have "steam" coming out of the machine?
You should be able to feel the heat.
If not, perhaps the water is not getting hot enough to dissolve the dishwashing powder.
Could you try using a liquid soap once and see what happens?
Be blessed.
Dish washer won't turn on when start button is pressed
Check your door switch. My dish washer would not work a couple of months ago, tore apart and messed with door switch and it has worked every since.
Pump running continuously, Yes there was a drain pack, have emptied water, float switch clicks when moved with screw driver. Only one red light shows ( last cycle - pots ) what else can I do... James
What type of dishwasher do you have? Has your kitchen floor flooded? If it has. The tray under dish washer isn't water tight. Moisture creates some unusual problems. Some of newer dish washer the there control panel under the top of door this also create problem especially if the switches are on the top of the door. Another moisture problem. I have repaired a new Electrolux dish was three times in less than 6 months. The floor would flood from the Maytag side load washing machine. The Madam of the house didn't tell me that the washing machine flooded the kitchen floor. No window in the door and sometime fill water solenoid would stick and fill the tube. When they open washing machine door, 12 gallons of water would spill. So I fix both of them. GB...stewbison
3helpful
I have constructa cr 5001 washing machine. its in german i need the manual in english thank u :)
John C.
1helpful
Please, be so kind to send me electric schema ( wiring diagrams ) for washing machine bosch V447 CV 5400 Constructa 2HK
John C
4helpful
Do not have the constructa dishwasher manual
service manual for dish washer construta
Apr 25, 2010 • Dishwashers
Instruction manual
Washing Machines Logo
Top Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
