Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Sounds like you have dirt in your fuel tank, as the heater runas it picks up the dirt in the filter plugging it up. When the heater shuts off, the dirt falls out of the filter. You start the heater back up and it does it all over again. Empty your tank and change the fuel filter. Should be fine then.
Posted on Oct 19, 2013
SOURCE: RM115 Reddy Heater forced air heater problem
air pressure should be no more than 3.5 psi. could be your pressure is too high and is blowing out the flame.
Posted on Dec 06, 2007
SOURCE: reddy heater 55000 btu R55A wont stay running
have you cleaned the little sponge filter?
Posted on Jan 09, 2009
SOURCE: reddy heater r60
with the top off see if there is an obstruction between the fan and the back of the heater chamber. also mounted on the backside of the combustion chamber is a hi limit with two wires coming out of it. this connects to the flame detector which is in the flame path. it is a copper cappillary with two spade connectors on it. once a flame is detected, it generates a millivolt signal that opens and maintains the main gas valve.
Posted on Oct 15, 2007
SOURCE: Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Posted on Feb 21, 2009
SOURCE: R55B Reddy Heater won't stay running. (PMS? menopause?)
Wow! Yours is the best description of a problem I have ever seen!!! Before I read the whole thing I figured you missed the pressure check as most people do but you nailed it. This is what I would try, Replace the air filter, the fuel filter, and the fuel (to make absolutely sure there is no water in the fuel) and readjust the fuel/air mixture. If that does not do it replace the cadmium cell they only cost pennies. Let me know how you make out and good luck.
hardrocko
PS, I have one of these so I am pretty familiar with the problems.
Posted on Feb 03, 2010
Here are a couple of tips that I
wrote that tell you how to troubleshoot a Torpedo or Reddy
heater...
Reddy
Heater - Troubleshooting Torpedo Heaters
Torpedo
Heater Pump Pressure Adjustment
heatman101
Feb 17, 2011 | Reddy R155D Utility Heater
heater...
Reddy
Torpedo
heatman101
Jan 13, 2011 | Reddy Heater-30-55,000 BTU Variable
heater...
Reddy
Torpedo
heatman101
Jan 08, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Here
is a tip about troubleshooting Torpedo Heaters
Reddy
heatman101
Dec 21, 2010 | Desa International Reddy Heater RHER155
Oct 13, 2010 | Reddy Heating & Cooling
Jan 04, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Dec 16, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Jan 27, 2009 | Reddy Heater-30-55,000 BTU Variable
Dec 20, 2007 | Reddy Heater-170,000 BTU Kerosene Deluxe
327 people viewed this question
