Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have a G.E. Profile PSS23MSWASS,model RM427537 side by side fridge/freezer, I cannot get freezer toto below 17, everything is melting, fridge seems fine.
I removed all items, unplugged unit for hours, removed ice tray (ice maker still works fine)? The controls are electronic. Noticed a small amount of icing on far wall of freezer, removed it. Waited till this morning, and still no luck. Any suggestions. My 5 year warranty was up in Nov/12 Thanks Cathy
Posted by catssoftail on
joel belden
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
Sounds like a defrost issue. Probably need a service tech look at it.
Posted on Jan 04, 2018
5 Related Answers
Robert Hirst
  • 833 Answers
SOURCE: Ge profile side By side ice maker water leak
This sounds like the float mechanism has gone bad. Remove it and have a look. It may be the float or the switch on it that is bad. There is also a solenoid valve. Parts kits are available. Shut off the water first!
Posted on Dec 22, 2007
Anonymous
  • 531 Answers
SOURCE: GE Profile Side By Side Melting Ice but still freezing lower half
you have adefrost problem
Posted on Apr 02, 2009
aasc
Mike Smith
  • 1606 Answers
SOURCE: Ge Profile fridge
Pull the refrig out from the wall , and remove the rear panel . Touch the compressor and feel if its hot or running . If the compressor is cool , then the main control board is bad ( since the compressor isn't running ) . If you can solder , you can repair the board (another paragraph ) . If the compressor is warm , then you could have a thermistor or 2 bad . This would have to be checked by a technician , unless you know how to get into the diagnostics procedure . Also , see if the compressor cooling fan is working and the black squirl cage is clean of dust .
Posted on Sep 06, 2009
Testimonial: "Quick, professional response."
mrfixit3667
Donald Rowan
  • 262 Answers
SOURCE: Hi. I have a GE GSS22WGMC side by side and for a
you might have 2 problems. First I think you have either a defrost problem or a evaperator fan problem.
Look at the lower back wall of the freezer and if you see frost build up then you have a defrost problem.
also open the freezer door and press the door switch button that makes the light go off and listen for the fan. if you don't here the fan its a good chance that it could be bad.
I would wait on the ice maker issue until the cooling issue is resolved because it could be causing the ice maker problem.
If you dont here the fan then ckeck it in 60 min again and if you still dont here the fan it is mostlikley bad.
If you do have the frost then one of the following compontents could be bad: Defrost heater, Defrost limiter or the Defost Timer.
Posted on Jan 10, 2010
Testimonial: "Thank you. We were having the same problem and this post helped."
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: GE Side By Side top portion of fridge and freezer not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 29, 2010
Hey i have problem with my fridge. my problem is freezer is melting ice. so i did all research and ended up with this. my heater is busted. i bought a kit, the "thermostat" with the 2 heater...
Defrost water will drip on the heater and ice should melt off. Did you get the proper thermostat ?
Usually marked with L followed by a number. Example L55 temperature which heaters are turned off.bobicehouse_15.jpg
Jul 10, 2011 | Refrigerators
Freezer compartment freezes okay to at least -5 degrees fridge will not cool below 17 degrees
Typically, the fridge gets its cool air via a vent from the freezer. If this vent becomes blocked, then the fridge won't cool. If there is nothing obvious blocking the vent (like a plastic bag) on either side then it is possible the vent is clogged with ice. To fix this, move your food to a cooler and unplug the fridge long enough for the ice to melt (12-24 hours).
Mar 03, 2011 | Refrigerators
Ice melts in freezer
check your inner box liner for cracks also your door seal's you have a air leak
Jan 13, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Water was frozen all inside the freezer and fridge temp was high
Self defrost mechanism may have an issue. If it stays on too long you will have excessive temps build up in refrig as well as freezer. There is also a defrost thermostat that is supposed to turn compressor back on when temps get too high - check that out also.
Apr 14, 2017 | GE Profile PSW26P Stainless Steel Side by...
GE side by side (purchased 2005; don't know exact model)
Defrost timer issue is my guess. It is generally located behind the rear inside panel in the fridge section. I'm guessing about $150-200 or so to fix it.
Jul 24, 2008 | GE Profile PFS22 33" Artica French Door...
GE Profile- Freezer/ Fridge at 56 wont go cooler!
check freezer for frost build up and if fan is blowing, check condenser, make sure its clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, check make sure compressor is running
Aug 25, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
184 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Mike McBirney
Level 1 Expert
gbob59
