Question about Champion 3500/4000 Watt Portable Generator
Fuel switch needs to be replaced does not shut off fuel intake
Posted by sherron carlos on
ddd228
    Sergeant:
  • 311 Answers
How did you stop it? Pull the spark plug wire?
There is a carburetor in there,somewhere.Pinch off the fuel line to or from the carb. I like needle nosed vice grips or a BIG hemostat.
Posted on Feb 21, 2013
Replaced fuel pump,strainer,fuel filter,battery,computer,car will only start when you pour gas down air intake.
Sorry this vehicle does not have a fuel shut off switch or inertia switch > that's ford ! If you pour fuel in the throttle body an it runs It's something with the fuel system , an if you replaced the pump an filter an regulator , It has to be electrical ! did you check voltage at the fuel pump relay ? What engine does yours have , 2.5 , 3.3 L ? There is a in line fuse for the fuel pump near the relay ! There are four relays front right of engine compartment mounted on radiator support cross member . The one for fuel pump is the one on the inside . Fuse is near there an there is a connector not connected to anything ,this is for fuel pump prime . Jump battery voltage to it a see if it runs then ! or replace relay !
Apr 25, 2015 | 1990 Buick Century
Car was running fine, shut it off, and wil not start, cranks, but does not start
Spray a small amount of fuel in the intake manifold and if car starts then your fuel pump or relays have failed. this is how i found out my fuel pump failed in my truck, it was running great, i shut it off and then it wouldnt start again, after pouring some fuel in the intake it started right up and then died , i changed the fuel pump and she runs great.
Nov 07, 2013 | 1998 Mazda 626
91 Ford Explorer 4.0 V6 5 speed manual. The truck will not start unless gas or starting fluid is sprayed into the intake. once this is done the truck will start and run normally just as before the...
Is this car fuel injected? If so there shlould be a flow sensor somewhere on the intake . Many of the patrs stores will loan an OBDI or II and you could do a diagnosis on the engine. This should indicate a faulty flow sensor among other problems.
Lots of luck.
I have the same year, model and engine with Automatic tranny, This was the year the Explorer replaced he Bronco and there seems to be a bunch of prototype parts. I just replaced the headlight/turn signal multifunction switch for $185.00. :(
Not a lot of information about this year. But it is a fun car :)
Sep 23, 2013 | 1991 Ford Explorer
How do you know if you have a bad fuel pump
Replace your fuel pump relay these are do go out once your car hits the 20 yr mark. under driver seat. look for a relay similar to the relay circled in my picture
Apr 21, 2012 | 1987 Ford Mustang
1993 chevy caprice classic wagon 5.0 8 cylinder hads a problem with engine shutting off with in seconds after start ! i did check for vapor lock in gas line, had new spark plugs replace, new fule...
Think the oil pressure switch keeps the fuel pump running once started. Suggest replacing Oil pressure switch. And no it won't effect oil pressure reading when it goes bad. The switch is a safety device. When you roll it over and the oil pressure drops the switch cuts off the fuel pump. Neat huh? Need some good feedback Thanks!
Jul 21, 2011 | 1993 Chevrolet Caprice
Won't start..new batt. Starts to turn over then just kinda rumbles. Fuel pump shutoff switch is stuck in the down position.
Shut off switch should be down if it was up there would be no fuel to engine,Sounds like the starter needs to be checked, Or the wires to it need checked,clean and tight.
Dec 11, 2010 | 1998 Lincoln Town Car
W just replaced the intake gasket on our 03 F35 6.0 Diesel. It started and ran then shut off. I put 3 gallons of Oil in it and now it won't start. Any suggestions? Is there a fuel shut off switch? If so,...
Did remove the injector pump or replace anything in the fuel system?
The fuel shut off valve is located near the FUEL iNJECTOR PUMP!
Sounds like u have air in ur FUEL SYTEM!
tell me more.
Nov 25, 2010 | 2003 Ford F350 Super Duty DRW SuperCab
94 ford Tarus ,,had fuel problem,,replaced fuel pump,,and fuel pump relay moduale,,and checked all fuses...Still no fuel pressure in manifold ..Car will start and run if gas is put in Air intake..Could it...
Fuel shut off switch should be located in the trunk on the same side you fill your tank on. The switch is guarder and you will have to figure out which way to press it
Oct 28, 2009 | 1994 Ford Taurus
1993 golf shuts down under hard
1 Inspect Carburetor Worn, Faulty or Damaged Carburetor. 2 Inspect Fuel Filter Clogged or Dirty Fuel Filter. 3 Inspect Intake Manifold Gasket Leaking, Worn, or Damaged Intake Manifold Gasket. 4 Inspect FreshAir Intake Hose Clogged or Damaged FreshAir Intake Hose. 5 Inspect Fuel Pump Low Fuel Pressure. 6 Inspect Fuel Injector Dirty or Worn Fuel Injectors.
Jul 02, 2009 | 1993 Volkswagen Golf
Champion 3500/4000 Watt Portable Generator Logo
74 people viewed this question
Top Champion Televison & Video Experts
Lee Hodgson
Lee Hodgson
Harrie
Are you a Champion Televison and Video Expert? Answer questions, earn points and help others
