Question about Casio CE CASI FX-9750GII-L-IH GRAPHING CALCULATO
How do I graph sinx on my Casio fx-9750GII calculator?
Posted by Jay Anderson on
k24674
  • Casio CE Master
  • 8,091 Answers
Turn calculator ON
If you see no icons, press Menu
Press 3 (Graph) draw your function. (more on that later).
If the first line of the display show Graph Func : Y= you should be able to draw your function.
If it says anything else, press F3 TYPE to select the graph type and select functional by pressing F1 key Y=.
After the graph type is set to Y=, type the second member of your function y= f(x) on the first line. Make sure the = sign after Y1= remains highlighted after you move cursor. Otherwise select the function by pressing F1:SEL. Press F6 Draw.
Be careful with trigonometric functions. If angle unit is radian, set window Zoom to standard. If angle unit is degree, you must open the Window utility and set Xmin=-190, Xmax = 190 to see at least a period.
Posted on Feb 24, 2013
Casio fx-9750GII is giving the wrong answer, is it broken?
Check the calculator with a simple 2X2 matrix that you can invert by hand easily and see if it gives you the wrong inverse for it. It is also possible that YOU made the mistake.
Jan 03, 2016 | Casio FX-9750GII Graphing Calculator
Hoe to Calculate nPr and nCr on a Casio fx-9750GII?
In Run/Mat screen, press the OPTN key followed by F6, the F3:Prob. The nPr and nCr tab are accessible. Type n then the relevant tab, followed by the r-number.
Oct 13, 2015 | Casio FX-9750GII Graphing Calculator
Where is the math button on the casio fx-9750G11
It is a calculator and prqactically every button is a MATH button. It depends on what MATH you intend to do. Put the calculator in Run/Mat screen then press the OPTN key. You will see several tabs. Press the function key under a TAB and explore what is offered. Go through all the keys (F6 also) and see what the new tabs do.
In general it is most helpful to read the manual that shipped with the calculator.
Oct 16, 2012 | Casio Calculator Graphing FX 9750GII...
How can i Make a Casio fx-9750gII simplify radicals?
I am sorry, but the Casio FX-9750GII does not manipulate radicals (roots). Maybe you mean fractions?
Feb 22, 2012 | Office Equipment & Supplies
How do i graph piecewise functions on the fx-9750GII
You must graph each part as a whole function and just pay attention to the one section in the bounds that it is active for. There is no way to only graph part of a function.
Sep 13, 2011 | Casio FX-9750GPlus Calculator
How do i use the fx-300es to graph
Sorry but you cannot do that. This is not a graphing calculator. However you can generate a table of values for your function (MODE TABLE) and use it to graph the curve by hand (pencil and paper).
If you need a Casio graphing calculator, one of the cheaper ones is the Casio FX-9750GII. Equivalent Texas Instruments calculators are the TI83PLUS/TI84PLUS.
Aug 31, 2010 | Casio fx-300ES Calculator
What is the better calculatorTI-83 Plus or FX-9750GII
If you have to restrict your selection to one or the other the Casio wins "hands tied behind its back". If you need convincing read on.
Advantages of Casio
Newer technology
About half the price
About twice the Ram
Uses iconic menus
Most screens have tab/menus: No need to scroll.
Conic graphic embedded in OS, not need for an extra application
Dynamic graphing embedded in OS, no need for an extra application
Has a reset button
Several types of statistical graphs that do not exit on TI83 (pie chart)
Ability to select the integration algorithm
Better screen resolution.
Jan 12, 2010 | Casio FX-9750GPlus Calculator
Casio CE CASI FX-9750GII-L-IH GRAPHING CALCULATO Logo
231 people viewed this question
Top Casio CE Office Equipment & Supplies Experts
Marvin
Marvin
Are you a Casio CE Office Equipment and Supply Expert? Answer questions, earn points and help others
