Question about Haier HVT12ABS Compact Wine Cooler
How do you replace the soldered fuse, top one is blown?
Posted by tazman282 on
Scneen won't light up
Check the fuse, transistors, cold solder joints.
http://s807.photobucket.com/albums/yy352/budm/Dell%20E153FPB/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Sep 04, 2010 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Help with RCA projection TV P46812BL (chasis ptk195AA)
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Sep 13, 2008 | RCA P52930BL 52" Rear Projection...
THE MONITORES POWER LIGHT KEEPS BLINKING AND THE MONITOR WON'T WORK AND STAYS BLACK
It has shorted out transistors in the inverter circuits, also look for cold solder joints, fuse.
http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Replacement board:
Aug 09, 2010 | Dell E173FP 17" LCD Monitor
My canon xl2 has stop functioning while shooting the power line is already shut down.. even i check the battery also but the battery almost fine..so please help
Possible main fuse blown.If no other solution available open the unit carefully and check the continuity of the fuses. If bad replace, it's made by littelfuse and is very small but not impossible to replace. It's suggested if you solder a new one on top of the existing blown fuse due to its size. Also ensure all ribbon cables are properly seated or it may result in blowing the main fuse.
Aug 01, 2010 | Canon XL2 Mini DV Digital Camcorder
Our power was just off for about 30 minutes but when the power came on my monitor is black and the power button is just flashing blue???
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside.
http://www.badcaps.net
Replacement board:
Jun 30, 2010 | BenQ FP731 17" LCD Monitor
Dead TV
U know basic electronic's,and u know how to do soldering?Have soldering iron,tools and solders?The power supply board,the board that the power a/c power cord plug into it.That the power supply board have these parts call capacitors are dead.These capacitors alway bulges up on it top or puff on it top.Check all around the power supply board and it supporting boards.Replaced these dead leakage bulges up on it top or puff up on it top.Or tries websites like Shopjimmy.com,Ebay.com to buy and replaced the whole refurbish power supply board.
May 28, 2010 | Hitachi 32PD5200 32 in. HD-Ready Plasma...
Convergience not working, three color pictures and concaved top and bottom. Is there a module that I can replace?
Check the small brown fuse FL231 located just to the lower right of the flyback. There are 3 small brown fuses. The middle one is FL231. Most likely it is blown. The reason it blows is because of the lead free solder used on the new boards. If you turn the board over you will probably find cracked solder joints on the flyback terminals. Re-solder all of the flyback terminals and replace the fuse if it is blown. This fuse tells the TV that it is a rear frojection TV and not a standard CRT
Feb 08, 2010 | RCA HD52W59 HDTV Projection Television
My LG refrigerator has a blown fuse on the circuit board. Is the fuse replaceable, it looks as though it is soldered to the board?
Yes. This fuse is replaceable, but, you will heed to De-solder the contacts, in order to remove the damaged fuse. this can be very challenging. If you are not an avid user of a soldering iron, i would just simply replace the board. If the soldering is not done correctly, this will cause the board to short, causing a spark.
I would , also, verify that the fuse is available for a non technician to purchase. Most vital components will not be available for purchase, if the purchaser is not a certified tech.
Oct 21, 2009 | LG LFC23760ST Side by Side Bottom Freezer...
Picture is 3D like with green, red, and bules lines at the top of the screen. It is also cuvred on the top, and bootom of the screen?
Your has probably blown fuse fl231, causing your convergence to go out. This is often a sign of a bad power supply. The fuse is located right next to the power supply. Replace the fuse and check flyback for bad solder joints. I fuse blows again, replace fuse and flyback transformer.
Oct 12, 2009 | RCA Televison & Video
HAier HVT12ABS wont turn on
I had the same problem. My 18-month old Haier HVT 12A wine cooler stopped working. I unplugged the unit, opened the back, and saw the circuit board and the two fuses soldered to the circuit board. The top fuse was OK. The bottom fuse, labelled FUSE2 5A/250V on the circuit board, was blown.
I went to Radio Shack and purchased a spring-loaded push and twist fuse holder ($3) and a bag of fuses (another $3). I soldered the leads from the fuse holder to the top and bottom of the dead fuse 2, inserted a new fuse, plugged it in, and it has been working fine ever since (1 month). If the new fuse fails, it is easy to replace. Total cost $6.
Oct 10, 2007 | Haier HVT12ABS Compact Wine Cooler
Haier HVT12ABS Compact Wine Cooler Logo
41 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
